Old 01-27-2014, 07:02 PM   #1
AirSpeed
AirSpeed's Avatar
Drove 70 miles in 4 wheel drive without knowing. Need indicator!
Drove my grandaughter home a few days ago, 70 miles and my trans case in my 72 K1500 was in four high, seems she hit the lever with her feet. I doubt I did any damage except burning a little extra gas but I would like to know next time! I had plans to instal an indicator light but never got to it. Any of you done this? What type of switch did you use? I'd like to see what you guys have come up with!
AirSpeed is offline   Reply With Quote
Old 01-27-2014, 08:53 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Drove 70 miles in 4 wheel drive without knowing. Need indicator!
Were your hubs locked? If not, nothing happened except driveshaft turning.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-27-2014, 09:56 PM   #3
Orange Crate
Orange Crate's Avatar
QU30048 Weather-Proof Indicator Switch is used in place of Poppet Plugs on NP205 Transfer Cases on trucks with dash or floor mounted 4x4 shift indicators. A Genuine OEM replacement for Chevy and GMC 1 ton trucks with sealed electrical connecters. Will also replace QU10515 blade type switches used on Ford, Dodge, and older GM trucks if optional QU90002 Pigtail is spliced into your indicator circuit. Made in U.S.A.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...
Orange Crate is offline   Reply With Quote
Old 01-27-2014, 10:08 PM   #4
Bigdav160
Bigdav160's Avatar
After that description I'm thinking I need two (twin sticked 205) but not at $115 a switch
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 01-28-2014, 04:30 PM   #5
OrrieG
OrrieG's Avatar
NP203 had a simple pushbutton switch on the shifter. I wired one side to ground, the other thru a light on my dash. You might be able to adapt it to yours. I made my twin stick set up, switch in on the 4 lock lever, I can figure out if its in high or low by engine speed! I got my switch at an electical supply store, standard threaded housing with two wires and about 1/2" throw. I wired the led thru a switch under the dash so i can turn the lamp off if I am off road a long time.
OrrieG is offline   Reply With Quote
Old 01-28-2014, 05:39 PM   #6
Orange Crate
Biggest of Daves:
Ya ya, I think I will not worry about it at all even if my hubs are locked in...! I also have a twin stinker NP205.
Old 01-29-2014, 11:38 AM   #7
This has never been an issue for me. I guess any time I've piled three people in the cab I've made sure they stay away from the shifter. I seem to recall keeping an eye on their legs and saying something,to the point they got tired of hearing about it and kept there dang leg off my lever! Other than that I just know if it's in or out
Old 02-14-2014, 02:27 AM   #8
Jdubs71
Jdubs71's Avatar
I once drove about 40 miles in 4-lo, but I knew it. Couldn't get it into 2-hi and didn't want to tow it. I thought I was going to need to rebuild the motor seeing as I had the tach pegged just to move at a decent speed. I know very stupid I was a young kid at the time. Plus side was nothing happened with the t-case and downside was the motor leaked oil after that. I wouldn't worry about it the 205 t case is bullet proof.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 02-16-2014, 09:39 PM   #9
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Check this thread out. I thought it was pretty slick. I was planning on doing something similar, but ended up going with a vac gauge so I no longer have an empty spot in my cluster.
http://67-72chevytrucks.com/vboard/s...d.php?t=449590
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
