01-27-2014, 07:32 PM | #1 |
Eagle Field Drags this weekend
http://eaglefielddrags.com/
Here is the link.. Super cool event at an old WW2 air base. Not track prep, 1/8 mile arm drop with no clocks. I am making a few suspension changes to hopefully make the truck work better out there. Put the 125lb tail gate back on Lowered the rear 2 1/2" Putting in a either a 100lb or 110lb spring in the rear with a 1" spacer (which ever will fit right) currently a 130lb Set the instant center longer and lower (70/2 instead of 57/5) to hopefully help transfer better Will be softening up the bound of the rear shocks Will be running on motor only. Might take some timing out of the motor for the initial hit. Should be fun!!
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
01-28-2014, 08:46 PM | #2 |
At the body shop.
Re: Eagle Field Drags this weekend
I'm wishing I can go. Maybe as a spectator.
" That didnt make it any newer " " Dont antique the equipment " |
01-28-2014, 11:09 PM | #3 |
Always a work in progress
If only it wasn't 6 hours away!! I'm in SoCal until the end of March
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
01-29-2014, 03:30 PM | #4 |
Looks like a real fun time.
01-31-2014, 11:54 AM | #5 |
You know we wanna see some videos man or atleast some pictures of your truck in action out there. Good luck.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
01-31-2014, 03:44 PM | #6 |
Sounds like I will be going to Sacramento instead. Will try for some video.
