Old 01-27-2014, 09:48 PM   #1
perro13
perro13's Avatar
6 cyl PS id help
one came off a 250, can anyone confirm? the other off a 292 with ac, I took off. just want to make sure if there are any brackets missing on either set up.
250?
292
pulleys don't remember which is correct.
perro13 is offline   Reply With Quote
Old 01-28-2014, 11:57 AM   #2
perro13
perro13's Avatar
Re: 6 cyl PS id help
anyone?
Old 01-28-2014, 12:14 PM   #3
60-66
60-66's Avatar
Picture one two and three look mid to late 70s maybe later ? Picture four has the early bracket but is missing two brackets and has a later pump and pulley. Your two pulleys if you can read a GM part number on them I can ID them for you.
Heres another thread on 6 cylinder brackets. For our generation of trucks 63-66 the 230, 250 and 292 uses the same brackets but different pulleys. http://67-72chevytrucks.com/vboard/s...d.php?t=605396
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
