Old 01-27-2014, 11:03 PM   #1
Colexv
question on stock ride height
i want to lower my 71' c10 but im torn on how far to go. i dont know if over the years my suspension has "naturally" lowered itself from having the weight on it. i dont want to order 2in drop springs and have my truck look exactly the same. right now at the rear outside fender well is about 33 1/2in and the front is 32in. any input?
Colexv is offline   Reply With Quote
Old 01-28-2014, 11:51 AM   #2
suspect
suspect's Avatar
Re: question on stock ride height
Even if 2 inch drop springs kept it at the same height, it would still be a good upgrade. Probably a smoother ride. Then you can move on from there. Add lowering spindles and blocks until you reach your desired height.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
