Old 01-27-2014, 11:28 PM   #1
ivorton74
ivorton74's Avatar
Finally starting my 5.3 swap!!
So on Saturday I finally had my truck trailered to the shop. And today I got some time off work to go the shop. Me and my buddy decided to paint the motor so I took all the accessories and exhaust manifolds off(got some f body manifolds on the way) and started cleaning all the gunk off. But since I can't pressure wash it I got a bucket of soapy water and scrubbing brush and started scrubbing it...its still not really clean...theres still alotta grease and dirt...any suggestions on how I can get it clean??
Anyway its starting to get exciting...I cant wait to start it for the first time. My buddy also got started on the wiring today and I still have to get a tranny...should have one soon though. Should also have the old motor and trans out really soon too.
ivorton74 is offline   Reply With Quote
Old 01-27-2014, 11:32 PM   #2
ivorton74
ivorton74's Avatar
Re: Finally starting my 5.3 swap!!...w/pics
more pics....sorry about some of the pics being sideways...took em on my cell phone
Old 01-28-2014, 12:53 AM   #3
Root2812
Root2812's Avatar
That's a nice looking square body! Where did you find one so solid up in the Dakotas?
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 01-28-2014, 01:02 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Finally starting my 5.3 swap!!
Looks like a good start! Just keep scrubbing them they will clean up nicley.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-28-2014, 01:17 AM   #5
ivorton74
ivorton74's Avatar
I got it from my inlaws...it sat for 5 years in their yard...i cleaned it up and painted it with rustoleum paint this past summer just until i can get it painted professionally
Old 01-29-2014, 10:21 PM   #6
ivorton74
ivorton74's Avatar
Camaro manifolds showed up today finally...got em from a guy on ls1tech who is parting out a z28...great deal at 40 bucks!
Old 01-29-2014, 10:47 PM   #7
Houston Ben
Houston Ben's Avatar
Nice! Wish I would have gone with different manifolds!
Houston Ben is offline   Reply With Quote
Old 01-30-2014, 01:23 PM   #8
Root2812
Root2812's Avatar
Nice score. I ended up getting LS6 exhaust manifolds from a corvette for $75 locally. Looks like you had a better deal.
My 1950 Chevy build
Old 01-30-2014, 02:40 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I can't tell, are those the cast ones, or the Steel formed ones?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-30-2014, 03:27 PM   #10
ivorton74
ivorton74's Avatar
they're cast I think
Old 02-01-2014, 12:18 AM   #11
ivorton74
ivorton74's Avatar
I need to buy some split wiring looms for my harness...anyone know what size looms I would have to get? also where can I find collectors for my f body manifolds? cant find em anywhere...
Old 02-01-2014, 02:38 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
That depends on the amount of wires, which sorta depends on what stuff/how your harness is setup, and which part of the harness you mean.
anywhere from the 1/2 small stuff up into the 1 or 1-1/2 stuff.
The braided loom is better quality than the split stuff, flexes more and seems a little more appealing. I have a mixture, but I like that stuff better.
As for the collectors, you can junkyard hunt some off a stock exhaust, see if a muffler shop has something they can work with, or just buy the flanges and make a set.
Old 02-02-2014, 10:39 AM   #13
83 Silverado
83 Silverado's Avatar
You may need to look in to a shallow slump pan for your swap, the stock truck pan is going to hang lower then the front cross member and your truck looks like you got a 6" drop in the front. This is the pan in order from my truck and it has every thing needed to swap.
http://www.summitracing.com/dom/part...2593/overview/
I'm just getting around to swapping a 4.8l into one my trucks, after having the motor for about 2 years. Keep up the good work.
83 Silverado is offline   Reply With Quote
Old 02-02-2014, 03:49 PM   #14
ivorton74
ivorton74's Avatar
oh yeah im actually looking for an f-body oil pan for it
Old 02-02-2014, 04:29 PM   #15
ivorton74
ivorton74's Avatar
why are those f body oil pans so expensive compared to a truck pan?
Old 02-02-2014, 06:47 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
50x more trucks were made that used the same part.
You can get the LH8 pan if you need more clearance without going all the way down to the fbody pan.
Old 02-13-2014, 03:42 PM   #17
ivorton74
ivorton74's Avatar
UPDATE...Having my trans ordered today...should be at the shop tomorrow or so. My wiring is pretty much done.. just have to get it taped up. The pcm is going to be inside the truck in front of my floor shifter. We're going to fab a center console and have it sit in there and have the shifter sit a little higher.Hoping to have the old motor out soon.We're just prepping for the swap and getting everything in order. The motor is going to be painted and gaskets replaced.
Old 02-14-2014, 03:12 AM   #18
littlevictories
that's the way to be
half the headache is getting all the part numbers in order
having the right diameter heater hose on hand
little things
good luck on the actual nuts n bolts part
littlevictories is offline   Reply With Quote
Old 02-14-2014, 07:39 PM   #19
ivorton74
ivorton74's Avatar
So went to the shop today and had the truck jacked up so we could check the rear end ratio and its a 3.08. We also decided to take the cab and front off together so we'll have a lotta room to work and my buddy's is going to start the engine on the stand first to make sure it runs properly before it goes in the truck. While the front of the truck is off I can clean and paint the engine bay.
Quick question about the transmission...when I looked on carpart.com for a tranny the is a choice between a tranny from a single cab and extended cab truck. Is there a difference between trannies in both body styles?
Old 02-14-2014, 07:56 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Shouldn't be, just may chance which driveshaft it has and whether or not a carrier bearing was used. (doesn't affect you)
The 3:08 is gonna be a little tall with an overdrive tranny. I'd consider swapping that out to something a bit higher to take advantage on the low end. (it'll be fine on the freeway, but you might notice it takes a bit more work in passing or accel at cruising speeds)
Old 02-14-2014, 10:44 PM   #21
79azc10
Looks good man
79azc10 is offline   Reply With Quote
Old 02-15-2014, 01:38 AM   #22
ivorton74
ivorton74's Avatar
What gears do u think I should run?...I was thinking about running 3.73s but I don't really know much about that. My buddy was telling me the 3.08 gear should help me with fuel economy. Around where I live there's alotta highways but I do want that passing power and all too. Also what tires do u think I should run? I was thinking about going with those radial t/a tires with wider tires in the back. My truck is lowered so I wanna go with shorter tires. It currently has 235/75/15s in the back and tiny 215/60/15s in the front.
Old 02-15-2014, 12:11 PM   #23
littlevictories
I have 28" tall tires and 3.73s and 2000rpm is just about 65mph
However, everyone in Oregon drives about 55mph on the freeways
So I end up pulling it down into 3rd quite often.
passing power? that's what the 4-2 downshift is for
just kidding, don't do that.
Old 02-15-2014, 01:33 PM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I have 235/75/15's as my "Replacement" rear size, when I'm not running the M/T 325/50/15' on my beadlocks.
3;08 will work, but the 3:23,3:73,4:11 have also been used to gain some advantage down low. My 4l80e has a very long second gear, so the more aggressive gearing helps.
Old 02-15-2014, 02:32 PM   #25
ivorton74
ivorton74's Avatar
pics from yesterday...had the truck inside to check the rear end ratio...engine is still on the stand with wiring almost complete. After that's done then we'll take the intake off clean up the motor some motor and then paint it.
again sorry about the pics...don't know how to adjust em
