Old 01-28-2014, 05:16 PM   #1
Hogger54
Hogger54's Avatar
Shock mount end differences?
Does anyone know the difference between loop, and bushing & sleeve shock mounts ends?
I can't find anything, and Monroe doesn't seem to like answering emails.
Hogger54 is offline   Reply With Quote
Old 01-29-2014, 09:59 AM   #2
Russell Ashley
Russell Ashley's Avatar
Re: Shock mount end differences?
Just guessing here, but I think loop ends go around a mounting stud like my 57 truck has, while bushing and sleeve is the type where the stud on the end of the shock is threaded and goes through a hole in the mounting bracket with rubber bushings and a steel washer on each side.
Russell Ashley is offline   Reply With Quote
Old 01-29-2014, 01:15 PM   #3
oldcouple
oldcouple's Avatar
http://arrc.ebscohost.com/ebsco_stat...EPLACEMENT.htm
http://www.monroe.com/assets/downloa...engthSheet.pdf
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 01-29-2014, 03:19 PM   #4
mr48chev
mr48chev's Avatar
The second link that Oldcouple posted will get you to the pfd that shows almost every Monroe shock with the ends it has and the extended and compressed lengths.
If you aren't a Monroe fan the Monroe number will interchange with almost all brands to some extent.
My ongoing truck projects:
Old 01-29-2014, 03:40 PM   #5
Hogger54
Hogger54's Avatar
Got all that, just wondering why one would have a bushing, and one wouldn't. What would be the two different installation types that would require the different ends.
