Old 01-28-2014, 07:43 PM   #1
1rippen6
Body mounts
Does someone sell the rubber body mounts for the Blazer not the polyurethane?
1rippen6 is offline   Reply With Quote
Old 01-29-2014, 09:39 AM   #2
briank
Re: Body mounts
Yea, most all the vendors do.
briank is offline   Reply With Quote
Old 01-30-2014, 01:02 AM   #3
Special-Ed
Special-Ed's Avatar
Re: Body mounts
is there a reason to get the rubber over the urathane mounts? it seams that urathane would be a better overall mount?... what gives?
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 01-30-2014, 10:41 AM   #4
Chulisohombre
Chulisohombre's Avatar
Re: Body mounts
Lmc truck sells both. I'm pretty sure jc Whitney used to Sell them too. The rubber is supposed to give less vibration through the body then poly mounts. But poly is a more solid feel and with my exhaust I wouldn't notice the extra vibration. I think the poly lets the body flex less than the rubber too. I got mine from poly performance for a hundred bucks. I like the poly better. Of course my rubber ones were forty years old when I replaced them. But it did stiffen up the body a lot. My rear ones had completely rotted out and the ass end moved around when cornering. Much better now.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
