01-28-2014, 10:23 PM | #1 |
Bucket Seats...Are these correct?
Found these on craigslist. Do they look year correct?...i thought they might not be but he claims they are 68-72...i knew someone on here would be able to tell. Thanks ahead of time.
Andy |
01-28-2014, 10:24 PM | #2 |
Re: Bucket Seats...Are these correct?
73+
01-28-2014, 11:04 PM | #3 |
Key to remember is what you want to do and how expensive they are.
69-75 bucket seat frames are the same. 69-70 uses 69-70 foams and covers. 71-75 seat foams are the same, with 71-72 covers or 73 up IIRC the adjusters are 69-72 drivers then 73 up pass brackets, pickup are 69-72 then 73 up pass blazer brackets are 69-72 then 73 up
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
01-28-2014, 11:12 PM | #4 |
I'd have to get you a pic or two Tim, but I found a 67 swb stepper with buddy buckets, i forget exaxtly what the spid says, but it is a cst. owner says they are original buckets....but they look just like these above. So frames and console could be right? Just wrong seats I guess?
Dont mean to jack your thread...found the same exact seats though
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
01-28-2014, 11:26 PM | #5 |
Tommy, if the buddy buckets look just like those above they are not original. A lot can happen in 46 years. Buddy buckets are on one frame that holds both seats and the console. They are entirely different from the 73+ seats shown above.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-28-2014, 11:36 PM | #6 |
Ok...I definitely remember that silver square on the seats
01-28-2014, 11:57 PM | #7 |
So these are not even 71 to 75 seats either correct? Because the top foam on these is not like the 71-72. The 71/72 have a a listing channel all the way around, and are upholstered completely different. I do upholstery and its obvious there not the same in that way. Thought there might have been some seats available in 67-72 somewhere i did not know about. Thanks for the clarification.
Andy |
01-29-2014, 12:04 AM | #8 |
Not sure where this is going but 67-68 buddy buckets are completely different as 71swb4x4 said.
Now 67 CST trucks came standard with the buddy buckets and they were optional in 68 on CST and all other trim levels. Nothing in that picture above would be correct for a 67 or even usable without modifications and duplicating the 69-72 bucket seat installation. The owner may be seeing buckets on the SPID and seats installed later like the square body seats above and not realize or care they are incorrect.
01-29-2014, 12:38 AM | #9 | |
As you noted they do not have the same foam shape as the 71-72 pickup seats. Below is a set of 73 seats clearly showing the 71-72 shape under a revised cover. At this point I'm beginning to think they may be 71-75? G-van seats or even motorhome built takeouts. If they have wood bases then you know they probably came from a motorhome. Sorry about the confusion by mistaking them for 73-75 stock pickup seats.
01-29-2014, 12:46 AM | #10 |
Roadtrip!
Look like the set i pulled from a 76 gmc pickup. Console also.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
