Old 01-28-2014, 11:16 PM   #1
67ctener
67ctener's Avatar
Can someone explain dual compressor wiring
There is tons of threads started on this subject but usually end up in a picture I don't understand. When it comes to wires my patience is slim. So here is what I have.... I'm running accuair switch speed with dual 400 compressors. All wires are accounted for other then power wire on each 400 and comp 1 wire that comes off switch speed harness. From here I'm pretty much lost. With one wire for compressors how do you wire 2? Do i need the 7 gauge accuair power wire? If anyone has a simple wiring explanation from this point it would be GREATLY appreciated.
67ctener is offline   Reply With Quote
Old 01-28-2014, 11:34 PM   #2
mongoose
mongoose's Avatar
Re: Can someone explain dual compressor wiring
it powers a relay for the pumps.. not the pump themselves.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
