Old 01-28-2014, 11:40 PM   #1
Classic-Steele
Classic-Steele's Avatar
Constant 12v (Wiring Harness Rework)
How are you guys setting up your fuse boxes? Are ya running only the orange ignition wires on constant 12v, and running everything else thru the ignition relay? Fuel pump, E fans, injectors, other sensors...
Classic-Steele is offline   Reply With Quote
Old 01-29-2014, 01:38 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Constant 12v (Wiring Harness Rework)
Take a look at the diagrams on lt1swap.com for some info on the harness rework. If you look in my build, you can see how my relays are layed out (all my wiring is exposed pretty much)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-29-2014, 01:45 AM   #3
Classic-Steele
You'll check out lt1 swap again. That's where I found all the pin outs and everything else.
Old 01-29-2014, 01:46 AM   #4
ls1nova71
ls1nova71's Avatar
Only the orange wires are constant, and the pink ignition wires need to be run off of a relay so to answer your question, yes.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-29-2014, 02:07 AM   #5
Classic-Steele
That was the way I was planning on running it too, but after looking at the current Performance fuse block setup I was second guessing myself. It looked like theirs had half of the fuses constant... Anyways that does answer my question. Thanks!
