Old 01-29-2014, 03:09 AM   #1
rs74
rs74's Avatar
Looking at a L92 6.2
Called a guy about an 07 Escalade 6.2 6 speed trans. This was a 4wd/AWD version I am told. Don't know much about them. I have been wanting to do something like this for my 85 C10 short bed. My understanding is that this engine is the variable timing type. I have heard that this may not be the best option. All I know is that this is supposed to be 27,000 mile engine and comes with the trans, transfercase, stand alone harnes, computer, and high pressure fuel pump.
Can mod these engines and make them run like you can the older LS and Vortec engines? If I got something like this I would want to put a healthy sounding cam in it. Also can the trans be made into a 2wd trans. The guy also said I should also be able to use the frame side clam shell mounts and it comes with the other mounts and would be able to move the engine back or forward either way if I wanted. Not sure about any of this and would like some feedback.Comes complete with all accessories.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-29-2014, 10:43 AM   #2
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Re: Looking at a L92 6.2
I can answer this one as i bought the exact same thing....
L92 with a 6l80 awd from a denali
and the answer to the majority of your questions is yes...
The motor was vvt... you can buy a vvt delete kit from texas speed and put a normal cam of your choosing in it...
http://texas-speed.com/p-724-vvt-delete-kit.aspx
or you can actually buy the majority of those parts from your dealer and maybe save some money if your parts dept give you a hookup...
I have part numbers for all somewhere...
next on the trans you will have to have it converted to 2wd... the estimates i recieved to do this were around 1k to go through the trans to check for any probs and replace the rear shaft and tail housing with a slip shaft syle unit
From there its up to you which directions you go..
I went ahead and upgraded my valve springs and had my heads machined and rebuilt... I also upgraded my trans to a 6L90 2wd from a similar year vehichle (i have heard this can be a headache but i am not to that point yet)
For install i would recommend Doug Thorley headers, CPP sheet metal perches and dirty dingo slider mounts as this combo is working for me...
You will also want to look into lower profile oil and trans pans as the truck one will hang down below the cross member...
chevyguy_72 is offline   Reply With Quote
Old 01-29-2014, 04:23 PM   #3
chevyguy_72
Vintage Evil
pics
Old 01-29-2014, 10:27 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
VVT...my '09 LY6 (6.0L iron block/L92 aluminum heads) I removed VVT easily in the process of a cam change with a new 4x timing gear, you just add the non-VVT timing cover. I went with the LS2 cam chain tensioner.
You can get some movement in your stock mounts, tho the sliding mounts provide a lot of mounting options.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-30-2014, 10:35 AM   #5
rs74
rs74's Avatar
Thanks guys. Not sure yet how this is going to play out as I am still trying to do my homework on it first.
Roy
1987 R10 shortie
