Old member
Has anybody installed a set of late model Tahoe are such seats and hooked all the electronic's up on them? If so could you please post some pictures and what you had to do to mount them and get them working. I assume 12 volts with relays and a switch for them. Looked at these on E-bay.
http://www.ebay.com/itm/160947815170...ht_1705wt_1124 Would rather get a nice set out of a Tahoe with all the buttons and switches along with the seat belts built into them. Man I love nightshift sitting here dreaming up stuff to do to the truck. ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Old member
OK, the LSx motor swap is about finished so for my next little project.
Well it may not be to little. How are you guy's that have installed the late model seats hooking up the heaters and such? Ok I figure the electric seat part is nothing more than 12 volts ran to the seat. The heater would need switches and 12 volts right? How are you mounting them and how do they sit? I found a sweet deal I think for a set of seats with the seat belts in them and full electric with heat $350.00 but no center console which is no problem since I have been wanting to build one anyway. ![]() ![]()
Re: Late model seats
Subscribed- I am hoping to do the same , or similar. I want heated seats- driving European cars has spoiled me.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
Old member
