Can anyone tell me if the rear trailing arms on 65-66 coil spring rear ends are the same as the ones on the 67-72 trucks. Also are the SWB and LWB arms the same length. Thanks.
Re: Trailing Arms
They will fit 60-65 had bolt on e brake brackets and 66-72 had riveted bracket f I remeber correctly you may have to swap brackets. They are the same length from swb and lwb
