01-29-2014, 12:27 PM | #1 |
What bastard u-joint do i need?
i recently installed my 69-70 12 bolt 3.08 in my 64'. the truck had a 70's-80's 10 bolt in it. How can i find out the size of the bastard joint? so i can hook up the newer smaller drive shaft up to the older rear end
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625 1969 Chevy Nova 2 dr I6 250/powerglide 1967,68,69,70,71,72 Chevy Frankenstein |
01-29-2014, 12:51 PM | #2 |
Re: What bastard u-joint do i need?
you just have to know the sizes and get the conversion joint that meets the measurements.
width of the joint, diameter of the cup and inside or outside clips. ron |
01-29-2014, 01:43 PM | #3 |
Give me cap diameters and also need to know if grooved or just a plain cap. Looking it up by application, 60-81 all take a precision 369 joint and mid 80's is a 534g. This would make it a precision #372. Driveshaft side is 1.125" grooved and rear end side is 1.063" plain. Hope this helps
01-29-2014, 01:48 PM | #4 |
Thanks guys I Appreciate it! and yes sir it Helps im gonna get the measurements when i get home!
01-29-2014, 09:26 PM | #5 |
Agree 372
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
01-30-2014, 08:26 AM | #6 |
Watch out for your cornhole !
My local parts store stocks them and they're not expensive at all.
01-30-2014, 08:32 AM | #7 |
That's the same one I used to put my TH350C/700R front yoke on my original drive shaft.
01-30-2014, 10:53 AM | #8 |
Sounds like the 372 is what im needing . so 372 is what ill get I Appreciate it guys!
01-31-2014, 02:51 PM | #9 |
01-31-2014, 02:59 PM | #10 |
No sir. Th350 and Th400 yokes are different.
01-31-2014, 03:20 PM | #11 |
10-30-2015, 10:17 PM | #12 |
But Found Her 25yrs Later!
I found a driveline from a 60's impala the exact length I need, so the worse case scenario is I'll need conversion u-joint?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-30-2015, 10:29 PM | #13 |
1961 crewcab
I had the same thing in my crew cab build, and needed a big to little U joint-
post # 270 http://67-72chevytrucks.com/vboard/s...646830&page=11
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
