Old 01-29-2014, 12:37 PM   #1
dmw319
Thumbs down Preventing rust questions, help!
So I have recently put on a bunch of new parts in the last year (disc brakes up front, suspension parts, etc). It seems that some of them are rusting already! I keep my truck outside under the carport, so it doesnt see rain but it does see drastic drops in temperature (recently) and a lot of moisture seems to form on the ground (epoxy'd concrete) and even when its foggy out, the whole floor stays wet till the weather gets dried up. So.. that's WHY its rusting. It never did this at my old house where I had an enclosed garage.
My question, can I help stop that in any way? My goal is to convert the carport to a full enclosed garage. But for now, would using a truck cover help? I know the moisture still might get in from under the truck, but I'm just trying to stop what I can right now. Eventually I'll take those parts off, clean the rust off and spray them with good paint, but no point until the garage is finished off.
Advice?
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 01-29-2014, 01:15 PM   #2
hugger6933
Re: Preventing rust questions, help!
A cover is not gonna help you except lighten your load in the wallet area by a few hundred. Now if you had some air flow[like a fan,as simple as a box fan might do it] to move the air out of the carport that may be a different story.What parts are you talking about that is rusting? Jim
hugger6933 is offline   Reply With Quote
Old 01-29-2014, 01:19 PM   #3
dmw319
Bolts to the bottom of my trailing arms, master cylinder, brake distribution block, some small spots on the headers...
Old 01-29-2014, 01:51 PM   #4
long'n low
long'n low's Avatar
spray some lube/wd40 on them?? it you put a layer of light oil should keep the water off and slow any corrosion.
long'n low is offline   Reply With Quote
Old 01-30-2014, 03:22 PM   #5
dmw319
i guess its worth a shot! anyone else?
Old 01-30-2014, 04:59 PM   #6
JWPOORE
Here is another type of lube/wd40 type spray.
http://www.fluid-film.com/
You can pick it up and in variety of sizes and ways to apply it. Ebay is also a good place to buy it reasonably.
JWPOORE is offline   Reply With Quote
Old 01-30-2014, 05:11 PM   #7
Cali72K20
Cali72K20's Avatar
this is what i use, this stuff works great. it turns rusty metal a blackish color.
i usually wire brush the affected area and spray away.
http://seafoamsales.com/deep-creep/
Cali72K20 is offline   Reply With Quote
Old 01-30-2014, 08:46 PM   #8
russgoodman
russgoodman's Avatar
I've got some stuff called Boeshield T9. Its made by Boeing for aviation use. Spray it on and wipe off excess and its supposed to last for a year. I haven't tried it outside but its been awesome in my shop.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554
2008 GMC Sierra Denali - 6.2L AWD - my daily
2011 Ford Flex Limited - Ecoboost AWD - wife's daily
1987 Buick Regal Turbo T - 63K miles - Strip/Street car
1965 Ford Mustang Coupe - 289, c4, 53K miles
russgoodman is offline   Reply With Quote
Old 01-30-2014, 09:34 PM   #9
Grumpy old man
Grumpy old man's Avatar
buy some tin roofing lie it on the ground and park the truck on top of it !, I have more than a few muscle cars stored this way and it works just fine ! a large tarp and your good to go just don't let the tarp go all the way to the ground it has to have air flow below it ...
Grumpy old man is offline   Reply With Quote
Old 01-31-2014, 12:57 AM   #10
Rod Run
Rod Run's Avatar
Any type of bare metal object stored outside is going to get surface rust, that's just part of nature.
I think when you epoxied the ground, you actually added to your problem. If it was bare cement, then the moisture would absorb into it relatively quickly. Now that it's epoxied, the water just sits there and beads up, so it has longer to sit around and cause rust under your truck. Sort of the same effect as wax on your paint
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 02-18-2016, 12:03 PM   #11
dmw319
Sorry to bring back a thread from the dead, but I think this is very true.
My epoxy coat in the garage is starting to peel after about 2 years (wasn't a very high quality one). I am thinking about just scraping the rest off and leaving it without any coat on it. It's just super ugly!
Old 02-18-2016, 02:40 PM   #12
Gromit
I like this stuff from www.blastercorp.com and available at my Home Depot for three or four bucks a can (buy two 'cause when you need it you need it and sucks to be out when for example you have something apart and can finally reach that inaccessible spot)..
If there is already rust this stuff will really calm it down..
It does wear off but takes maybe 8 to 10 months and then just give it another shot.
One example - recently I had my window regulator out and I was able to fit the can inside the door and spray the spots in the upper inside corners by the hinge and by the latch - no other way to get at that except maybe with a soda blaster..
Don't get it on your disk brake rotor though - it is wax based..
Gromit is offline   Reply With Quote
Old 02-18-2016, 03:04 PM   #13
dmw319
Thanks!
Old 02-18-2016, 04:14 PM   #14
Mrturner1
Scrape that epoxy off, acid wash the cement, and then stain it to look like something you'll like. Sometimes bare cement is ugly but a little work and the right kind of stain and you will be happy AND the water won't bead up
Mrturner1 is offline   Reply With Quote
Old 02-18-2016, 06:10 PM   #15
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
After driving Chevy and GMC's FOR 35 years... my driveway is sealed with 10w30, 80w90, and Dexron/Mercon... if a Chevy ever stops leaking... it's out of oil! LOL
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-18-2016, 06:24 PM   #16
mlongkc
Does carport have a metal roof?
mlongkc is offline   Reply With Quote
Old 02-19-2016, 10:50 AM   #17
67 chevelle
67 chevelle's Avatar
http://www.ebay.com/itm/281919158839...%3AMEBIDX%3AIT
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-19-2016, 10:53 AM   #18
dmw319
Nope, its part of the house. I really want to enclose it to make it an actual garage.
Old 02-19-2016, 02:18 PM   #19
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Old school method here in Florida for the pre '73 Steel trucks was to dump the burnt motor oil back into all the trucks nooks, seams and wherever else. It would slow the rust or prevent from starting. Uh, still works too...
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 02-19-2016, 03:14 PM   #20
Fatherflash
Fatherflash's Avatar
As a stop gap type measure, have you tried desiccant bags? Put them near the component and they will help absorb airborne moisture. They will not solve the rust issue however, they can help control the moisture trapped in the air and environment. You can find the bags through Amazon. Also search for silica gel and damp rid. Don't put the desiccant bags directly on bare metal. I put mine in open plastic bags near the component. I also coat the item I am worried about with WD-40. This combination works for me.
My other vehicle is unmanned....
Fatherflash is offline   Reply With Quote
Old 02-19-2016, 03:26 PM   #21
dmw319
thanks for the advice fellas!
I am going to paint a lot of the parts that are rusting with some POR15 this weekend and hopefully that will help!
Old 02-20-2016, 08:53 AM   #22
You have bare metal and moisture in the air. It either needs paint, an oil to form a shield, or a product that converts iron oxide to iron phosphate. The converter lasts a while, but needs to be redone in time. Same with oils. The converter is what you need prior to painting, if you go that route. Covering will hold the moisture and even create it through condensation. Circulating air with a fan helps, but you are blowing moisture. It's just the way unpainted metal gets.
