01-29-2014, 05:26 PM | #1 |
very squeaky belt
so.... I got the 5.3 engine. the belt started squeaking ..... I wasn't sure if it was a pulley or something, but figured id try the stuff in a spray can that's supposed to quiet squeaky belts. it made the speak louder than ever. I stopped at the mechanic to have him listen and told him I sprayed the belt dressing on it....
so he says, oh that stuff doesn't work, and he puts a couple of dabs of some lubricant on the inside side of the belt. I started it up and it was instantly quiet again... stayed quiet for most of the day. now it squeaks again, louder than ever. any suggestions?
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
01-30-2014, 11:56 AM | #2 |
Re: very squeaky belt
Bite the bullet and put a good quality belt on it. I've use nothing but goodyear gatorback belts. Never had one squeal.
01-30-2014, 05:57 PM | #3 |
So when the belt gets old it squeals ? I've had the truck since 180k miles . Has 235 now. I never changed the belt . Is a little lube on the belt quieting it for a while an indication the belt needs replacing ?
01-30-2014, 09:42 PM | #4 | |
You now have Rubber/Petroleum goo all over the pulleys from the dressing & their "Polished" from the glazed belt, The pulleys will need to be cleaned, A stainless wire brush will rough-up the polished grooves, Finish it off with a cotton rag & some rubbing alcohol to get all the oil off. If you just throw a belt on...You will contaminate it, And the noise will come back. |
01-30-2014, 10:18 PM | #5 |
God i hate that spray stuff never works and takes forever to get off the pulleys like said get a good belt clean the pulley and your good too go
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-30-2014, 10:21 PM | #6 |
Thank you for the tips. Where do you buy the gator back belt ? If u have a link , please share
01-30-2014, 10:30 PM | #7 |
I see them on eBay for around 30 bucks..... Which part number is for me (5.3 engine)
01-31-2014, 01:22 PM | #8 |
The local stores want to sell me a Dayco belt.... and theyre saying there's two different possible belts, depending on which alternator I have ?? two different auto parts stores said the same thing...
so now im worried about ordering the wrong gatorback from the internet. I cant tell which alternator I have. it says Delphi on it if I clean the pulleys well, the Dayco belt should be fine right ?
01-31-2014, 08:44 PM | #9 | |
On a 105amp....You can't see the Stator. On a 130amp....Yon can see about an Inch of the Stator. |
02-01-2014, 09:01 PM | #10 |
thanks Clinebarger. based on your pictures, I have the 130 AMP alternator.
02-02-2014, 07:26 PM | #11 |
02-02-2014, 07:46 PM | #12 |
I don't know , I just bought this truck 4 years ago
02-06-2014, 06:27 PM | #13 |
update, its all fixed and nice and quiet. The root cause of the squeaky belt was probably the leaking water pump. I replaced the water pump, cleaned the pulleys and installed new belts. sounds good now!
