Old 01-29-2014, 06:43 PM   #1
dwcsr
Hollister Road Co.
dwcsr's Avatar
55-1 Floor Replacement Absolute Sheetmetal
I have a truck cab in the shop now that needs a floor and toe panels along with some kick panel work and some door work. The floor kit is an Absolute Sheet Metal 751002 for a stock firewall. The kit consists of the toe boards, toe board extensions, floor boards. front cab supports, master cylinder door, transmission tunnel, a floor brace, some screws and a set of alignment brackets. I haven't used this kit before and it was purchased by the customer but so far the kit looks to be of very good quality the instructions appear to be good, pictures are a little washed out but still view-able. We are starting this on Friday and will post start to finish and follow the directions in the paperwork so you can see for yourself if you want to tackle this type of project. This is a board members cab from Lufkin Tx so if it looks familiar that's where you saw it.
dwcsr is offline   Reply With Quote
