Old 01-29-2014, 06:55 PM   #1
cam.man67
cam.man67's Avatar
Help sorting out mech. fuel pump?
Decided to replace the fuel pump on Lester, we'll see if it gets him running again. Got fuel up to there, so it should. Here's the confusing part:
The pump I pulled off and the new one look identical...except that teh old one had a line close tot he inlet. Oddly it ran to the fuel filter. It doesn't look like the primary fuel inlet, so my question is what is the purpose that inlet/oulet/bypass/whatever? Do I need it? Is it a deal-break that the new pump doesn't have it? Does it have something to do with the fact that the orignial engine was a Olds diesel? The old pump part number is Carter 0-1955.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 01-30-2014, 06:48 AM   #2
cam.man67
cam.man67's Avatar
Re: Help sorting out mech. fuel pump?
Ok, so I;ve been reading...looks like the mechanical fuel pump I took off had a return line and for whatever reason, that was the line the PO put the filter on. Now the question is...do I need that return line? Or can I cap it off and not worry about it?
Old 01-31-2014, 10:57 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
the main is 3/8
vent is 5/16
the return is 1/4 and it helps with vapour lock
better to use the right one
but i've seen the two line used instead of three
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-05-2014, 12:59 PM   #4
dwntwn
dwntwn's Avatar
X2 what Motornut said.
I've capped the return line and had no issues, other times had flooding and hot-start issues. Not worth the headache, just get the right one, you'll probably be happier in the long run
1966 c10, short fleet, 402ci 700r4
1988 r20 Suburban 454ci tbi, th400 (12v Cummins soon)
1980 shovelhead, hardtail, open primary
1998 FXDWG
dwntwn is offline   Reply With Quote
