Old 01-29-2014, 10:49 PM   #1
Houston Ben
Houston Ben's Avatar
How low can you go
How low can you go on an LS swap without having to worry too much about hitting the oil pans?
Houston Ben is offline   Reply With Quote
Old 01-29-2014, 11:08 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: How low can you go
Well I mean....that might depend on what truck you have
or
what oil pan your using
or
what mounts your using
or
really...ANYTHING?
on there is only one oil pan, unless you mean the trans oil pan, which will then depend on which trans...
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-29-2014, 11:14 PM   #3
Houston Ben
Guess I should have thought about that...
Old 01-30-2014, 01:12 AM   #4
Special-Ed
Special-Ed's Avatar
you can go as low until it touches...
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 01-30-2014, 09:47 AM   #5
Custom 68
Custom 68's Avatar
I used a Camaro oil pan and dropped it low. It is just above my cross member. I tried the truck one first and it was a couple inches below the cross member and that just wouldn't work. I built my own mounts.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 01-30-2014, 10:46 AM   #6
Houston Ben
Ya, I guess it was kind of a dumb question. I am not familiar in this area and my engineering mind was thinking everyone has the exact same problem I do.....but then again, I am not an engineer...
Anyway, thanks for the replies, it appears my trans and engine pans hang below the frame (6L80) and I am afraid I will punch a hole in them if I drop it any lower. Guess I will keep it how it is.
Thanks again all.
Old 01-30-2014, 12:12 PM   #7
ls1c10
ls1c10's Avatar
Camaro pan with dirty dingo mounts.
ls1c10 is offline   Reply With Quote
Old 01-30-2014, 12:45 PM   #8
Matt Cramer
Are you worried about how low you can set the engine in the chassis and oil pan to crossmember clearance, or how low you can set the suspension and oil pan to ground clearance?
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 01-30-2014, 01:58 PM   #9
Houston Ben
Matt, I am worried about how low I can set the suspension and oil pan to ground clearance. I would like mine a little lower but I am worried about the ground clearance on the oil pan. I also have the DD mounts and guess I could go with the Camaro pan.
So this brings up another question or thought... is the front cross member is the lowest point on the truck? I think I'm screwed either way as both my engine and transmission pans hang lower than my cross member.... oh well, guess I will live with how it sits.
Old 01-30-2014, 02:37 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
It generally is the lowest point, but the truck pan will sit below the xmember on pretty much every swap. The LH8 pan will come about even to the crossmember...mine looks like it hangs below, but having bottomed the truck out, I never hit the pan.
Once all my driveline stuff was set, my trans pan looked even with the frame, but at ride height it actually is just above it. The drivetrain should have a little bit of an angle on it, so its not actually a flat plane (*4)
This also depends on how far forward or aft its all set, because at 4*, an engine further rear TECHNICALLY sits lower, but its a very small amount.
The camaro pan has more clearance, otherwise people have used a stock pan and modded it for a little more width at the same capacity (like the old school Moroso pans )
I'm on a 66, with the 71/2 style suspension and crossmember stuff. With adapter plates, my oil pan just barely hangs below the cross. My truck is fairly low as well, I maybe have 3"-4" under the crossmember at static height.
Old 01-30-2014, 03:01 PM   #11
mrhurt73
Im using the caddy CTS-V oil pan, and my truck sits down till the body touches the ground.
i picked that pan to clear the crossmember and still not be too low.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 01-30-2014, 03:25 PM   #12
Jonboy
Slots go on anything!
Me too. It tucks behind the crossmember quite nicely.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-30-2014, 03:26 PM   #13
Hart_Rod
Hart_Rod's Avatar
+2 (68 C10 & 69 Burb)
Hart_Rod is offline   Reply With Quote
Old 01-31-2014, 03:23 PM   #14
mooseknuckles
mooseknuckles's Avatar
I'm using the muscle car/LH8 pan, trans dapt adapter plates....the pan is about a 1/2" above the bottom of the crossmember....oh and a it's "z'd" 3"
mooseknuckles is offline   Reply With Quote
