Old 01-29-2014, 03:30 PM   #1
66mustangguy
Thinking of converting 71 2wd suburban to 4wd need suggestions
thinking of converting my 71 2wd suburban to 4wd. what is the best approach to this?? should I find a 71 long bed truck and replace the body mounts? What is the best approach?
I have a 93 donor truck, but I am thinking this isnt a good idea to drop the body on this frame....
66mustangguy is offline   Reply With Quote
Old 01-29-2014, 04:01 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Thinking of converting 71 2wd suburban to 4wd need suggestions
Welcome to the board.
If you scroll down through some of the older threads below you will find some info on this. I can't really help you but I think most guys use the '67-'72 4x4 pickup frames because they are much easier to find. You would have to make a couple of changes to the pickup frame but nothing major.
LockDoc
Leon
Old 01-29-2014, 09:11 PM   #3
72c10suburban
72c10suburban's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
72c10suburban is offline   Reply With Quote
Old 01-30-2014, 09:53 PM   #4
jeffro308
[QUOTE=66mustangguy;6498385]thinking of converting my 71 2wd suburban to 4wd. what is the best approach to this?? should I find a 71 long bed truck and replace the body mounts? What is the best approach?
QUOTE]
I've got the same plan for my 69 panel. I'm going to use the stock frame and install a different engine cross member, spring hangars, Sliders rather than shackles and a divorced transfer case.
jeffro308 is offline   Reply With Quote
Old 01-30-2014, 10:00 PM   #5
vectorit
What?
vectorit's Avatar
Personally, I'd look for a roached out 4x4 67-72 Suburban. Then swap frames, and sell the donor as a roller.
Converting from 4x2 to 4x4 on these trucks is a challenge trying to make a 4x2 to 4x4, plus you have the rear to deal with if you are running coils for suspension. Sure it can be done, but comparing work involved in making a chassis work to swapping in a 4x4 chassis?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 01-31-2014, 04:45 AM   #6
jeffro308
Sometimes the work involved and the completed project is the point.
Old 02-03-2014, 09:51 PM   #7
Onelefttoget
Hey Iam thinking of doing just the opposite text me 3605616926 maybe we should talk
Onelefttoget is offline   Reply With Quote
Old 02-03-2014, 11:55 PM   #8
Captainfab
60-66 Nut
You are correct.....that will be way too much work.
I always recommend keeping your original frame and just changing the suspension and running gear. There are advantages to having a frame and body with the same VIN. Hopwever if you do happen to find a 4x4 frame and running gear of the correct vintage, so as to make it an easy bolt on swap, be sure you get a title with the frame, and follow the proper legal procedures in your state.
Old 02-27-2014, 09:01 PM   #9
68 TT
Still plays with trucks
68 TT's Avatar
x2
Keeping a proper paper trail of where the cab/body & frame came from is very important in many states. Mine requires an inspection by the state patrol with a body swap to certify the pieces used are not stolen then a new VIN number is affixed to the cab that matches the frame VIN.
Even when like with our trucks that only have a partial VIN on the frame and the whole VIN on the cab the frame is still the primary component for registration in my state and it over rules the body VIN. So with your swap the title for the parts Sub would be the one you needed for registration.
Every state is different so you need to know what your state requires to know for sure what you need to do to make this legal.
If the vehicle ever gets wrecked and the insurance companies get involved the mismatched VIN could cause you way more grief than you think. Not that yours is not a valid transaction but as an example say the donor vehicle you purchased came with no title but you bought it anyway on good faith that it was not a stolen vehicle. You complete the work to get the body swap done and once the Sub is back on the road it gets hit in an accident. Say the insurance estimator at the body shop finds the partial VIN on frame doesn't match the body during his inspection. If he runs the numbers and finds the donor you used for the frame was reported as a stolen vehicle then your entire vehicle could be confiscated on the spot with no compensation to you what so ever. This applies even if you unknowingly had a parts vehicle that was a stolen vehicle.
I lost a car I purchased legally with a title that matched the VIN on the dash this way. Body shop I had replacing a floor pan found a hidden VIN on the floor that didn't match the dash so they looked for the other hidden VIN's and they all matched the floor. They tore into the dash to look more closely at the dash VIN and found it had been taken from the body of another car so the police ran the hidden VIN numbers and found it had been stolen 25 years earlier and never recovered. Dash VIN fasteners were not visible without taking the dash board apart so it was not caught even by the police department that inspected my car when I transferred the title from CA to WA. The original owner who had the car stolen from him in 1972 got it back and I got nothing to compensate me for it even though I thought I had purchased the car legally and had a clean title for it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-27-2014, 10:12 PM   #10
pwdcougar
pwdcougar's Avatar
Great information. Where is the vin on our frames?
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-28-2014, 02:34 AM   #11
Gobuffalo
Gobuffalo's Avatar
It can be found on the left frame rail. The one I have always found is stamped on top of the frame about halfway between the axles. If the body is on the frame you will need a mirror.
I sometimes find it also stamped on top of the left frame rail by the steering box.
Here's mine at the middle of the frame.
Gobuffalo is offline   Reply With Quote
Old 02-28-2014, 02:40 AM   #12
Gobuffalo
Gobuffalo's Avatar
And by the steering box.
Not the complete number. Some of the beginning and the last 5 are from the end.
My understanding is the one in the middle is the most important as the one in the engine compartment is easily faked.
