Old 01-30-2014, 02:59 AM   #1
reddogg
ridetech
Just placed order with ridetech. Level 2 kit with 5 gal airpod, The BIGRED 3/8" solenoids, xtra 5 gal tank, xtra AMK compressor and muscle bar. Any tips or comments on install. 86 c10 short bed.
reddogg is offline   Reply With Quote
Old 01-30-2014, 08:01 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: ridetech
Take your time and measure everything 5 times. It gets done faster that way.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 01-30-2014, 11:12 AM   #3
BowlerJon
Re: ridetech
great kit, easy install... watch your knuckles
BowlerJon is offline   Reply With Quote
Old 01-30-2014, 01:22 PM   #4
Pro Performance
Pro Performance's Avatar
Re: ridetech
Here are just a few tips, not specific to the RideTech system, but general air bag installation. #4 is very important!
1) Make sure to run your air lines away from anything that can damage them. Keep away from headers, sharp edges, etc. If you run through the frame, use a grommet.
2) Cut your air line straight and square, insert all the way into the PTC fitting, and give a small tug to make sure it is fully inserted.
3) Teflon tape works on threaded fittings, but I highly recommend the Loctite 545 sealant, which works very well.
4) When done, enjoy your new suspension and ride quality.
- Travis
Pro Performance is offline   Reply With Quote
Old 01-31-2014, 12:01 AM   #5
reddogg
Re: ridetech
Thanks for the tips. I will be asking more as I start the install
