Old 01-30-2014, 12:16 PM   #1
72blaz
72blaz's Avatar
Crossmember Question
I bought new bedsides from Southern Kentucky..which they look pretty nice..however as my body shop guy took down my old ones..they discovered that my crossmember is too big...apparently this one was from a truck..and it's too large.... I haven't had an in depth conversation yet..but I have looked for 72 blazer crossmembers..and I'm having a hard time finding them...so..what are my options?.,, any help would be greatly appreciated.
1972 Chevy Blazer
Check out my build:
http://67-72chevytrucks.com/vboard/s...d.php?t=560741
72blaz is offline   Reply With Quote
Old 01-31-2014, 10:30 AM   #2
Chulisohombre
Chulisohombre's Avatar
Re: Crossmember Question
Have you Tried the restoration places. I don't know if they have them. Other than that you can make a custom one or have one made for whatever you need.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 01-31-2014, 10:43 AM   #3
Jdubs71
Jdubs71's Avatar
What crossmember are you referring to? Post a pic if you're able to i would assume since you're replacing bedsides that it has something to do with that. A lot of blazer and truck parts were interchangeable.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 01-31-2014, 11:31 AM   #4
72blaz
72blaz's Avatar
I am going over to the body shop in about 2 hours.. I will take some pics and post what I'm talking about....
1972 Chevy Blazer
Check out my build:
