Old 01-30-2014, 09:05 PM   #1
DieselRat
Brake switch for S10 pedal assembly
I've got an S10 pedal assembly and brackety in my 54 truck. Hooking up my wiring I realized that I either lost or took off whatever was on it as a brake switch. Now I'm wondering (because Im not an S10 guy) is it a pedal actuated switch thats on it stock? What is the common way to integrate a switch of some sort to turn my brake lights on when I hit the pedal?
DieselRat is offline   Reply With Quote
Old 01-31-2014, 12:31 PM   #2
55metalmonkey
Re: Brake switch for S10 pedal assembly
You could either find an original brake switch for the pedal, which if I remember correctly is off the brake pedal arm or install a tee in the brake line and put in a fluid activated switch like the one below.
55metalmonkey is offline   Reply With Quote
Old 01-31-2014, 12:48 PM   #3
stewdecky
stewdecky's Avatar
I put a "T" and a pressure switch from Speedway and it works great.
stewdecky is offline   Reply With Quote
Old 01-31-2014, 01:54 PM   #4
youngrodder
youngrodder's Avatar
I used a universal Brake pedal switch. You can mount it several different ways. Worked for me.
You can find them on ebay for under $20.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-31-2014, 02:06 PM   #5
55metalmonkey
Found an image for the S-10 brake light switch, not sure if it's the same year you are using but I'm fairly certain that it should be.... GM isn't so creative that they change things that work. it's about $10 at any local parts store
Old 01-31-2014, 04:21 PM   #6
DieselRat
Thanks for the help fellas. Gives me some options to play with. I will probably just mount up the original if I didnt hack that brackety up too bad !
