Old 01-30-2014, 09:45 PM   #1
ZMAR
ZMAR's Avatar
TH350 won't upshift
I've checked the fluid while everything was hot. Good there. Pulled the governor out and shook it, plunger is working freely. Vacuum is ran and hooked to manifold not carb and free of any cracks or kinks. When you take off in drive it revs way up there and won't shift. It's like you push the clutch in and it idles back down while you are still rolling. Any ideas here fellas?
71 c10 swb
ZMAR is offline   Reply With Quote
Old 01-30-2014, 09:55 PM   #2
Sabaka454
Sabaka454's Avatar
Re: TH350 won't upshift
How is the gear on the governor?
Sabaka454 is offline   Reply With Quote
Old 01-30-2014, 10:04 PM   #3
ZMAR
ZMAR's Avatar
Looked brand new
71 c10 swb
Old 01-30-2014, 10:09 PM   #4
Sabaka454
Sabaka454's Avatar
And you checked the drive gear as well on the output shaft? Did you verify there is vacuum with the engine running at the vacuum modulator? Is the detent cable hooked up and properly adjusted?
Old 01-30-2014, 10:12 PM   #5
buddy_1
buddy_1's Avatar
Is it slipping or just revving high? Check the downshift cable for proper adjustment. If its too tight it will try to stay in passing gear.
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 01-30-2014, 10:23 PM   #6
ZMAR
ZMAR's Avatar
I didn't look inside the hole where the governor slides in. It did rotate when I pulled it out and it came out very smooth. So I unhook the vacuum line at the modulator w/ motor running and see if there is vacuum? I did not look at the cable but will check that right now
71 c10 swb
Old 01-30-2014, 10:28 PM   #7
ZMAR
ZMAR's Avatar
Revving high. It has a stall in it but I doubt it's 5k! I'm going to check the cable
71 c10 swb
Old 01-30-2014, 10:29 PM   #8
ZMAR
ZMAR's Avatar
What about completely unhooking the cable? What would that do? It's got 38s and super low gears
71 c10 swb
Old 01-30-2014, 10:47 PM   #9
ZMAR
ZMAR's Avatar
The cable is not too tight.
71 c10 swb
Old 01-30-2014, 10:51 PM   #10
rs74
rs74's Avatar
That was my thought. Had one get so hot on one side it melted it down to a smooth indentation. The rest of the gear was find except that one spot.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-31-2014, 06:00 PM   #11
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Check for vacuum... keep the kick-down cable on there you'll want it with the 38s, regardless of your steep gears.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
