Active Member
![]() Join Date: Nov 2013
Rear mount fuel tank with leaf springs
I'd like to move my fuel tank out of my cab on my 1967 K10. I've seen a few threads on installing a Chevelle or Camaro gas tank and putting the filler behind the rear lisence plate which is the option I'd like to go but I'm not sure if the tank will clear my rear leaf springs. I'm wondering if anyone has any experience with this or should i persue another option? My K10 is a LWB if that helps.
Thanks Adam
1967 K10 292, SM65 Transmission & NP205 Transfer Case My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=605048 |
Re: Rear mount fuel tank with leaf springs
If you don't have a rear bumper hitch (mounted to the frame rails under the bed) then there are many fuel tank relocation kits available.
Have a read of this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=368348 |
Active Member
Thanks for the link, I tried to get out to my truck tonight to get some measurements but I couldn't due to the weather so I thought I'd see if someone here could help.
Much apprieciated Adam
