01-31-2014, 10:09 AM | #1 |
6 in drop on burb
hi does anyone have 6in drop springs in a suburban? if so what shocks did you use? will a truck c notch fit a suburban frame?
70 SWB STEPSIDE 70 BLAZER 09 challenger |
01-31-2014, 11:52 AM | #2 |
Junior Member
Re: 6 in drop on burb
I have 4" spring with a 2" block and used a CPP notch. I was running KYB gas-adjust and just switched to KYB GR2 for a softer ride.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
01-31-2014, 04:29 PM | #3 |
thanks do you have a part #?
02-05-2014, 12:56 AM | #4 |
I was just doing the research myself on my suburban build and opted on going with air bags in the rear with the cpp notch. $105 for the CPP notch off ebay and purchased two Air Lift Dominator 2600 bags with schrader valves. (Around $120)
The 6" springs are $105 on ebay so just for a little more you could be riding on air! If you go with a cpp notch, they do sell a heavy duty one if you will be towing with it. |
