Old 01-31-2014, 02:49 PM   #1
bigmac73
bigmac73's Avatar
New Rotors
I bought a set of new rotors from LMC a while back and also replaced all wheel bearings and seals, as well,
the rotors came with new bearing races installed so I did not use the races that came with the new wheel bearings.. (also from LMC)
did i make a mistake by not using race from new bearings? any opinions are appreciated
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 01-31-2014, 02:52 PM   #2
imjeff
imjeff's Avatar
Re: New Rotors
As long as both were new and they are adjusted right, you should be good to go. The problems usually come in when you use new with used or used with non-mated used. I usually feel the wheel center periodically for heat. I've been daily driving these trucks for decades and heat always precedes failure.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 01-31-2014, 02:57 PM   #3
bigmac73
bigmac73's Avatar
Re: New Rotors
the reason i asked is i have the truck up on stands while doing the tranny overhaul, i walked over to the front right wheel and grabbed it and i got a little side to side action out of it .. I am going to pull out the bearings and check them out and grease them up , maybe i did not quite get them tight enough, it has about 10K miles on it since i replaced them
Mike
Old 01-31-2014, 03:02 PM   #4
jocko
jocko's Avatar
Re: New Rotors
Side/side means (normally) not enough tightness on the castle nut. If you check the bearings and confirm they are still good, repack them, then tighten the castle but by hand until it's "pretty darn tight" - ensure no side/side movement, and then back off until you can insert the cotter pin. Someone probably has the exact torque reading to give you vice the "pretty darn tight"... If you still have side/side movement, then you may have an issue. But, concur with prior posts - different mfgr brgs and races should be interchangeable. I've done this and had no problems. They are built to a spec, not to a set. Having said that, all bets are off on overseas parts... The mixing I did was with fed mogul and stock gm - really kinda one and the same.
Old 01-31-2014, 03:03 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: New Rotors
Like Jeff said, new bearings with new races are fine. Maybe recheck your adjustment to address the play.
Also, please don't buy rotors from LMC. They stiff you on price of parts and shipping. You can buy 5 lug rotors at the local parts store and six lug rotors from vendors who are cheaper than LMC. I don't know if there's a single thing in the LMC catalog that you can't buy cheaper elsewhere.
Old 01-31-2014, 03:04 PM   #6
imjeff
imjeff's Avatar
Re: New Rotors
Check it for up and down as well. If it's loose bearings it will wobble on either axis. The races may not have been seated all the way. A brass drift and BFH will prevent this in the future.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 01-31-2014, 03:09 PM   #7
bigmac73
bigmac73's Avatar
Re: New Rotors
will check it all out when the snow thaws, I haven't heard the term "BFH" since my steaming days years ago....
Mike
Old 01-31-2014, 06:45 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: New Rotors
Could also be a worn out tie rod end or worn ball joints.
I agree with TXFF... I would source the rotors from a local parts store before I'd order from LMC. Any parts supply should have them.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-31-2014, 08:12 PM   #9
bigmac73
bigmac73's Avatar
Re: New Rotors
every piece under the front end is brand new all replaced last summer, so it has to be a wheel bearing adjustment
Mike
Old 01-31-2014, 09:23 PM   #10
mgchevyparts
mgchevyparts's Avatar
Re: New Rotors
Don't over tighten them, tapered wheel bearings are better off slightly loose then too tight.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 02-01-2014, 08:06 AM   #11
bigmac73
bigmac73's Avatar
Re: New Rotors
well my dad taught me years ago, to adjust them until the wheel wont turn then back them off slightly until the wheel turns and the castle nut lines up with hole
Mike
