![]() Join Date: Apr 2005
EFI Wiring harness prices
I'm looking for suggestions for an EFI harness for my son's 68. It's a stock LS1/4L60E out of a 2002 Camaro Z28 (25K miles). I have purchased Speartech in the past and they are great for custom stuff, but they are more pricey. I found a PSI harness online for around $550,
http://secure.ultracart.com/catalog/PSI/HAR-1012.html Thoughts or suggestions on this harness (or other harnesses and prices with links). Thanks in advance
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-31-2014 at 02:56 PM. |
Re: EFI Wiring harness prices
I have a PSI harness in mine, and I also bought a reflashed pcm from them....decent quality, a few minor problems, but the price was right.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Problems with the harness or computer? I have HPTuners and will be doing the tune myself.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
a bit of both...some things in the tune weren't turned off.....nothing major, but it does throw a code....and the harness had a wire pinned wrong for the 4l80e, that was a pain in the ass to find!
meowMEOWmeowMEOW
I used fuelinjectionconnection the price was in the same ballpark as what you listed. Quality was really nice, I have all the pics in my build. Came with its own relays/fuse box and layed out nice. Only 1 hiccup with alternator plug, which may have been my fault, they took care of @ 0 cost and overnighted the parts.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I used Howell Engine Development the price was in the ballpark . Quality was really nice, comes with its own relays/ fuse and CE light/ALDL. and labeled;
I wish I would have asked them for a longer TAC cable so I could have placed it elseware. I did order a 5 ft. tail for the ECM I did have them re program ECM and I sent them the TAC and peddle and asked them to make sure everything worked. They said they hooked it up on their mule and all functioned. I have not had it on the street but there are no CEL flashing!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
LS performance wiring...425 shipped with integrated electric fan harness. Braided spilt loom, not that cheap plastic crap.
Also their harness comes off the back of the engine for a cleaner layout.
I am using the factory harness on mine and modifed it to come out the back of the engine. Using EFI live to program the PCM.
Like this guy said, I just bought one and completely happy with it. Joe will build it however you want, just let him know your configuration and he'll take care of it. I have a couple pics in my thread of one.
Old member
The one in mine is from LS1 wiring and it to comes off the back of the motor with fuse block. Everything was labeled and marked.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Do they have a website?
#13 |
Old member
I think this is it. The first link is prices of harnesses.
http://www.currentperformance.com/eng_mgt.html http://www.currentperformance.com/index.html
#14 |
They have a Facebook page. When I head to the shop later I'll post a pic of his business card. I've seen the various harnesses and his is bar none. A turn key harness and his customer support is great too.
#15 | |
That said, judging from the Fb page, their stuff looks pretty good. |
#16 |
The Waco Kid
Rob, if you read up and search the web, PSI does not have that good of a reputation. I have not used them, but the bad publicity made me stay away. I ended up going with BP automotive, Bill was great to work with and has always returned my calls even on weekends. Greg
#17 | |
Old member
![]() Quote:
![]() https://www.facebook.com/LsPerformanceWiring
#18 |
I used Bill @ BPAutomotive.
http://www.bp-automotive.com He's a sponsor on tech and has been very helpful at more than one occasion during my build. Taking calls at off hours/weekends just to make sure I was taken care of. I'd highly recommend him and his product. His pricing is also very competitive. I've yet to see a bad review of his work.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
#19 | |
#20 |
I used 150 tunes to thin down my LQ9 harness. The show "trucks" used them for an LQ4 they put into a 1971. Cost was $250. I posted some pics of the harness in my build thread. I haven't fired it up yet.
#21 |
Ok, after a lot of research, I'm leaning toward one from BPAutomotive. Now I'm debating whether or not to get the starter and ignition relay option. Any thoughts?
#22 |
Get all the options. I did and I don't regret it.
You won't be disappointed with Bill, he's a GREAT guy. If you know you're going to need the harness but don't have it yet pay him for it and that'll save your spot in line. I did that and I had mine back within a couple weeks. |
#23 |
I bought the dbw PSI harness. Trucks not running yet but I layed out the harness and it seems to fit good. Nice connectors. Jon has answered all my questions on the phone and email even after hours.
#24 |
![]() Join Date: Oct 2013
I'd say go with this guy too... I'm cutting up my own, but if I give up on it I'll definitely be giving him my business... His work looks top notch like the others have mentioned.
