Old 01-31-2014, 03:09 PM   #1
ls1man
ls1man's Avatar
mustang ii steering link pics please!
I need some steering column linkage pics with mustang rack in AD trucks.
Thanks.
ls1man is offline   Reply With Quote
Old 01-31-2014, 08:47 PM   #2
oldman3
oldman3's Avatar
Re: mustang ii steering link pics please!
These are not the best pics, but all I have. First pic shows being set up for length of shaft. I use wooden dowels to put inside the universal, once everything looks OK, then I cut the metal one. Second pic is metal shaft installed. I must tell you that I moved my steering column over about 2-1/2", and down a little from the stock location, so it would clear my headers better. You can see old spot in first pic. Mine runs straight from the joint on the column to the rack. Hope this helps....Jim
oldman3 is offline   Reply With Quote
Old 02-01-2014, 09:24 AM   #3
Advanced Design
Advanced Design's Avatar
Here is one with a vibration reducer joint at the column, DD shaft, single joint, and support to get around the exhaust manifold.
Advanced Design is offline   Reply With Quote
Old 02-01-2014, 10:09 AM   #4
Chevy-49
Chevy-49's Avatar
ididit 32'' column, modified column drop, TCI IFS
Chevy-49 is offline   Reply With Quote
