Junior Member
![]() Join Date: Aug 2010
Hardtop with Sunroof/window
Hey Guys,
This is aftermarket right? |
SKINNY TIRES RULE!
Re: Hardtop with Sunroof/window
Yup. I never understood a sunroof in a convertible top.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
![]() Join Date: Apr 2006
I saw that on CL. Not a bad looking project.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
![]() Join Date: Jan 2001
Aftermarket and, to most Blazer owners, not very desirable.
It's a double wall though so a top could be found. Could always throw a single wall on. There is one for sale on the Sacramento CL for $400.
Its an easy fix for a good fiberglass guy. Im with bouncytruck, why would anybody want a sunroof on a convertible top. I had a single wall top that i had patched and it turned out nice.
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
SKINNY TIRES RULE!
FYI, the tops are not fiberglass, but I can't remember what it is they are made of. There are a couple of top repair threads.
Aftermarket as much as I know. I always thought they were ugly. If you don't ever want to take the top off I guess this would be a help in the summer.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
You are correct its made from a hard reinforced plastic, but the repairs are done similar to fiberglass repair.
I've repaired mine with fiberglass and bondo. Works the same as patching metal. A hole as big as that one I'd have no clue how to do it and make it look good.
I believe it's called SMC. It's similar to fiberglass, but uses a different resin.
i kinda like the idea of a sunroof.... because sometime you cant be topless... and a sunroof is the next best thing...
i know in floriduh where im at, from about may thru november you cant go topless... because it rains almost every day granted its usually for less than 30 minutes then mr sun comes back out...
Ed will be known as the Tiger Woods of the integration business |
