01-31-2014, 08:47 PM | #1 |
U Felts for Slider Channels
I am rebuilding my four slider windows. I inherited a bunch of rubber and felt with the project, but one u channel felt is bad. I checked with Steele and they don't supply it. Anyone know where this can be sourced?
02-01-2014, 01:54 AM | #2 |
60-66 Nut
Re: U Felts for Slider Channels
Are you sure Steele doesn't have it? I know I have seen it online listed with standard profiles and I could swear it was on Steele's site.
02-01-2014, 10:26 AM | #3 |
I think I got my felts from Brothers.
02-01-2014, 12:21 PM | #4 |
I just replaced mine with C R Laurence 10G96 glass run channel. It's a perfect replacment. It comes in 96" pieces and can be bought at your local glass company. I got it cheaper buying it local then getting it on line.
02-01-2014, 12:58 PM | #5 |
Yah I sent the photo to Steele and they said that they don't have it.
02-01-2014, 09:37 PM | #6 |
You'd have to check the measurements but this may fit. Universal felt kits..
http://www.wescottsauto.com/WebCatal...indowParts.pdf |
02-02-2014, 02:43 PM | #7 |
I bought some from Classic Parts a few years ago. Not sure if they still handle them.
02-10-2014, 02:40 PM | #8 |
Truck Shop in Orange,Ca. has kits for your sliders. I purchased 4 of em for my 64 Sub. Kits are pretty decent. They give you about two inchs of extra material on everything thats in the kit so "measure twice, cut once.
DAMN ! WE'RE IN A TIGHT SPOT !!! |
02-13-2014, 12:05 AM | #9 |
in the process of doing mine bought the rubbers from steele rubber they are pricey but the square parts of the window are perfect,bought the flexible auto channel 96(2.4m) 75000073-25 part number is 10g96 it comes in 96 inch strips 25.30 appease from crlaurence then you also need felt strips for the windows to slide against part number ym396 its 14.25 appease crlaurence.com 18004216144 if this helps i just rebuilt 4 sliders and im in the process of installing them
02-13-2014, 01:30 PM | #10 | |
69-what exterior weatherstrip did you end up using? Did you buy the ones from Steele with the formed corners?
My '65 Suburban Resto build-- http://smg.photobucket.com/albums/v6...65%20Suburban/ And it's story of being 'saved' http://www.jalopyjournal.com/forum/s...d.php?t=631495 |
02-15-2014, 01:14 AM | #11 |
hi hemi i did buy the ones with the formed corners i have one in mounted so far and will post a picture soon hemi thanks jon
02-22-2014, 08:29 PM | #12 |
So if I buy,
Weatherstrip, quarter window p/n: 70-1593-81 Vulcanized sliding quarter window channel. Please order carefully. Depending upon the configuration of your vehicle, you may need to order two units of this part number or in combination with 70-1728-81. $209.50 $209.50 This is just the rubber pieces that hold the windows to the body? I still need to buy felt for inside the channels? What else? Looks like I'm going to have 1k in window parts
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
02-25-2014, 11:57 PM | #13 |
Yah the cost to rebuild the sliders is hell! Especially when you have four of them. Makes the solid pane conversion looks good...and you still have enough to put in AC!
Thanks for all the info. In the end the CR Laurence lead was the ticket. Seems that many of the parts are available to window shops through standard channels, and the specialty part is just the rubber moulding. Scottie. |
