Old 07-21-2003, 01:14 AM   #1
69GMC396
More Questions
After I blew my intake gasket I decided to take the heads off to put in a new head gasket. What should the head bolts be torqued to when I put them back on? Its a 1969 GMC 396. I also sheared one of the bolts off of my intake manifold so I ordered an edelbrock performer intake. Can I run a plain old carquest intake gasket or should I get a special kind like Edelbrock recommends?
Thanks,
Nick
69GMC396 is offline   Reply With Quote
Old 07-21-2003, 06:03 AM   #2
dmurphy68
go get you a haynes manual for our trucks they are about 14 bucks and have all torque specs in there. good book to have imo
Darren
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour.
- George Washington
No free man shall be debarred the use of arms
- Thomas Jefferson
Later Darren
http://www.myspace.com/dmurphy68
dmurphy68 is offline   Reply With Quote
Old 07-21-2003, 07:04 AM   #3
GMCPaul
Use GM original intake gaskets or pro-seal by Eldelbrock, or Fel-Pro-Printo-Seal BUT DO NOT USE Fel-Pro Perma-Torque they will leak.
The torque for heads are 65 ft lbs, be sure to get a book showing tightening pattern. Myself I prefer to torque heads in 3 steps, first follow pattern at 25 ft lbs, then 45 ft lbs, then 65 ft lbs.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 07-21-2003, 09:32 AM   #4
Randy70C-10
Randy70C-10's Avatar
http://www.geocities.com/meanracing/...formation.html
Randy70C-10 is offline   Reply With Quote
Old 07-24-2003, 07:03 PM   #5
Jwill41
Jwill41's Avatar
I just got the intake and install kit from Jeg's. They supply Mr Gasket 720-101B from thier catalog. Are these gaskets going to work ok? I assume that they would supply the correct ones but I want to be sure.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
