Old 02-01-2014, 09:03 PM   #1
Bearcamp
Installed airbags and still dont set low enough.
I just got done installing the airbags on the front of my 63 and is still 4 inches off the ground. I wanted it on the ground. I have 2 1/2 inch drop spindles and the air bag kit done to it. I was wondering what can be doin this. Are my shocks keeping it from dropping? Help please. Also the bottom front shock cup are in place where they belong.
Bearcamp is offline   Reply With Quote
Old 02-01-2014, 09:29 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Installed airbags and still dont set low enough.
Yup. Take the shocks off and see if it drop farther. Do you have a c notch? Four inches off the ground does seem pretty low for that set up though.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 02-01-2014, 09:33 PM   #3
Slow Build
Slow Build's Avatar
Are the tires bottoming on the inner front fenders?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 02-02-2014, 01:56 AM   #4
NEWFISHER
NEWFISHER's Avatar
Cupped arms? Pancaked crossmember? Cut out wheel wells? All those are required to go further than you are now.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 02-02-2014, 08:22 AM   #5
Bearcamp
Stock crossmember, a arms etc. spindles are 2 1/2 in drop. Not hitting inner fender.
Old 02-02-2014, 09:42 AM   #6
Bearcamp
Just removed the front shocks n no difference. From the bottom of the rocker to floor I have 6 1/2 inches. Way too much. I'm stumped.
Old 02-02-2014, 10:07 AM   #7
wjjeeper
wjjeeper's Avatar
Post a pic of it off the blocks
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 02-02-2014, 10:46 AM   #8
Bearcamp
Here's one off the blocks.
Old 02-02-2014, 10:55 AM   #9
chad64chevy
chad64chevy's Avatar
like newfisher was stating, you will have to pancake the crossmember, cup your lower control arms 1.5-2" and cut out your inner fender wells! theres a few threads in the project and build threads you can check out, like coulter! theres even a how-to pancake your crossmember!
by the way I like the spikes on the front bumper where did you get them?? was size are they??
chad64chevy is offline   Reply With Quote
Old 02-02-2014, 11:13 AM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
How tall are the lower bag cups that set in the a-arms?
They can be trimmed down to 1-5/8" tall.
You are going to need a different front wheel/tire combo to go lower anyway,...
Keith
Convert to disc brakes.
Old 02-02-2014, 01:13 PM   #11
dr69burb
dr69burb's Avatar
Do you still have the bump stops in? Could be hitting those.
Baggin 64 lwb project
http://67-72chevytrucks.com/vboard/s...d.php?t=537406
dr69burb is offline   Reply With Quote
Old 02-02-2014, 02:41 PM   #12
mooseknuckles
mooseknuckles's Avatar
.....cup lower A-arms, pancake cross member, upper ball joints are prob binding as well.....how tall is the tire?
mooseknuckles is offline   Reply With Quote
Old 02-02-2014, 05:20 PM   #13
Slow Build
Slow Build's Avatar
Take some pics of the front suspension aired out. Let's get some eyes on the subject.
Past GM Trucks:
Old 02-02-2014, 06:25 PM   #14
Bearcamp
Pics but I do believe with everything stock this is as low as I'll get it.
Old 02-02-2014, 06:49 PM   #15
Bearcamp
That's a pic with it jacked up n no weight on it.
Old 02-02-2014, 10:14 PM   #16
LVPhotos
LVPhotos's Avatar
Those bags are bigger than my rears.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-02-2014, 10:32 PM   #17
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I think what they are asking for is a shot (like that) with all the weight on the wheel, with NO air in the bag (i.e. aired out). This will let people see what is preventing it from dropping lower.
From what I see, having the bump/steering stop on the lower arm is going to be your limiting factor. Most people who install bags on stock arms, they remove that to get the lowest drop.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-02-2014, 11:09 PM   #18
chevy2junk
chevy2junk's Avatar
Cut the snubber stands off.
chevy2junk is offline   Reply With Quote
Old 02-02-2014, 11:20 PM   #19
mano
mano's Avatar
Yeah its hitting the metal bump stop stands. Tires will be the next problem. Tires look to tall. If you play with the step up you should be able to get the crossmember to the ground. Cut the lower cups down to.
mano is offline   Reply With Quote
Old 02-02-2014, 11:51 PM   #20
joedoh
joedoh's Avatar
I'd route those airlines away from the tierods unless you want an automatic adjustment when they rub through.
and I would guess the balljoints are in a bind, those are pretty tall tires.
deservedly so, bags should be bigger in the front. I see guys use huge bags in the rear and wonder why, a small bag will perform better in the rear. it has to do with the weight and the volume of air to lift, a really big bag without weight will lift a LOT with really low pressure, leading to a wallowing ride. in the front, the motor and cab have plenty of weight not to mention it is compounded by the lever of the a arms, a big bag will lift higher with less pressure than a small bag
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 02-03-2014, 08:00 AM   #21
PGSigns
PGSigns's Avatar
On mine I put a cup in the lower a arm to let the bag st lower in the arm. I cut off the bump stop brackets also. I ran my lines out the back of the cross member to get them out the way. I have more backspacing on my wheels and it keeps them off the fenders and the inner fenders rest right on the top of the tire. With my wheel and tire combo my cross member is 2 1/2" off the ground aired out. The frame and cross member is what you need to be looking at when you dump the bags and not the rockers. That will tell you what your limiting factors are. If you look under mine the first thing that it would land on is the exhaust.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-03-2014, 06:13 PM   #22
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
lower cup is the issue!
Sick5 is offline   Reply With Quote
Old 02-03-2014, 07:58 PM   #23
Bearcamp
The bump stop is removed in the pic of iton the ground. The cups are 3 inches and was thinking about cutting them down to 1 1/2 inches. The spikes I got off ebay and they are 3/4 inch (they fit a 3/4 inch bolt head) Ball joints are not binding and neither are the shocks. When it's ired out the shocks still have about 4 inches of travel. I believe in order to get it lower is to cut down the cups but I believe I'll wait til I get the box back on and see how it sets. Oh yes the tires,,,,,,,,,,,,,,,,,they are 235-60r-15 and only about 27 inches tall.
Old 02-03-2014, 08:21 PM   #24
mooseknuckles
you'll need to do a "Z" or a drop member to lay frame....remove the bag "cup's" completely and cup the lower control arms... and you'll need to do something with the inner fenders....oh, and everything else that was mentioned...
Old 02-03-2014, 08:43 PM   #25
Bearcamp
Would I get another 1 1/2 inches if I just cut the cup from 3 to 1 1/2?
