Old 02-01-2014, 09:45 PM   #1
elf w/capital T
Question Firewall holes for Vintage Air
I havent purchased the kit yet for my 68, but I smoothed my firewall and I want to prepare the holes now, before i paint it... anyone know which size holes I'll need for the grommets?? I'm not using the plastic cover thing if you are lost.
any help would be appreciated!
elf w/capital T is offline   Reply With Quote
Old 02-01-2014, 11:07 PM   #2
magicoolbus
magicoolbus's Avatar
Re: Firewall holes for Vintage Air
Smooth firewalls seem to look best with the bulkhead fittings available in lots of places. Here is the one that VA has in their catalog.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 02-02-2014, 12:09 AM   #3
elf w/capital T
Thanks! but I was thinking about going with a bulkhead type fitting, but would it be possible to just use the "stock" equipment?
Old 02-02-2014, 02:19 AM   #4
cafetony
I'm installing a vintage air unit right now. I also bought that square bulkhead
fitting but decided not to use it and go with the stock vertical unit, that came
with my unit. The problem using the bulkhead unit is that you will have to make all new line inside and not that it's that big of a deal but I like the hard lines that came with the unit.
I'll send a few tomorrow with the holes cut out.
Here is a pic of what i'm about to cut
cafetony is offline   Reply With Quote
Old 02-02-2014, 09:33 AM   #5
elf w/capital T
Tony, Thanks man, how do you convert from the unit to the new lines under the dash?
Old 02-02-2014, 05:24 PM   #6
cafetony
well if you use the stock set up everything you need comes with it.
If you end up going with a block style you would have to make your own soft lines with AN fittings or custom hard lines.
Old 02-03-2014, 08:20 PM   #7
elf w/capital T
awesome, thanks! ...but....anyone know which size holes I'll need for the grommets??
Old 02-04-2014, 12:06 AM   #8
magicoolbus
Download the instruction sheet from VA website. The templates are in the manuals.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
Old 02-05-2014, 09:29 PM   #9
elf w/capital T
I did, only cout out sheets they have are the front dash pieces, I sent them an email. lets see what they got......?
I was just hoping somone had one laying around and could measure them, but no biggy.
Thanks magicoolbus
Old 02-05-2014, 11:21 PM   #10
Z10
Z10's Avatar
The V/A firewall block off plate is actually steel not plastic. Here's a pic of mine. More pics on my build thread.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 02-06-2014, 03:04 AM   #11
elf w/capital T
oh neat, my mistake. thanks for the update.
Old 02-06-2014, 11:23 PM   #12
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
If you will pm your address I would be more than happy to send you a template...
Kyle
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 02-06-2014, 11:39 PM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
That's good to know. The one on my C10 was plastic (that was 2006), but I noticed the firewall position/plates on the newer kits are different. I recently installed a new kit in my 65 mustang, but they don't need a block off plate. Mustangs used that big goofy under dash center unit so the firewall only had two holes for the heater core (the factory A/C lines are on the driver's side).
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-07-2014, 01:11 AM   #14
Z10
Z10's Avatar
Here's a better pic before I painted it to match my firewall.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-10-2014, 10:30 AM   #15
Zukowner
Zukowner's Avatar
Attachment 1209337
Where did you get that square grommet for the fuse box hole? Or is that the factory plug?
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=614365
68 & I'll Owe You 1
Zukowner is offline   Reply With Quote
Old 02-11-2014, 12:58 AM   #16
cafetony
new wiring harness. you have to cut the old hole out a hair but it fit perfect
when its done.
Old 06-07-2014, 08:05 AM   #17
elf w/capital T
Tony, thanks, cut the old hole? Niiiicceee paint...what color is that?
Old 06-07-2014, 07:19 PM   #18
Fitz
I used the vertical arrangement of fittings to make routing the lines up the inside of the fender easier.
In the photo he small line is 6 AN or 9/16 - 18 and the large ones are 8 AN or 3/4-16. You'll need a step drill to get the next size up for clearance for the threads which are the same on both sides of the bulkhead fitting I used..
Fitz is offline   Reply With Quote
Old 02-08-2015, 07:26 PM   #19
elf w/capital T
thanks guys! NIICCEE Fitz!
Old 02-08-2015, 11:38 PM   #20
9teen69
9teen69's Avatar
The VA kit is awesome but doesn't provide grommets for the lower two lines. I just measured them and purchased two grommets from Lowes. Sorry I don't remember the diameter.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 02-11-2015, 03:36 PM   #21
screaminchevypickup
Laid Back
The reason the bottom two holes do not have grommets is so the heater hoses can slide into the firewall and seal off the openings.. Which also allows for the heater hose clamps to be put inside the cab for a cleaner look.
72 chevy swb
Kyle
Old 02-11-2015, 04:26 PM   #22
9teen69
9teen69's Avatar
Aww grasshopper!
Old 10-27-2016, 11:21 AM   #23
Hart_Rod
Hart_Rod's Avatar
Old thread, but here's what I did...
Hart_Rod is offline   Reply With Quote
Old 01-12-2018, 01:49 AM   #24
lux
Hart Rod, That looks like what I would like to do. Can you explain how you made the connections from the A/C unit to the bulk head? I have a Vintage Air Gen 4 surefit and a inline Vintage Air bulk head plate. I thought I would have to discard the kit hard lines and make my own soft lines for in the cab between the bak head and A/C unit.
lux is offline   Reply With Quote
Old 01-12-2018, 09:02 AM   #25
Hart_Rod
Hart_Rod's Avatar
I used 4 bulkhead fittings and had them "welded" to the hard lines that came with my VA Sure-Fit kit. I also made my own bulkhead plate as I couldn't get the Vintage air one to work with the new lines.
