02-01-2014, 10:25 PM | #1 |
Bolt length for P/S on 72
Howdy, going over all my parts to convert my manual to power steering and realized I don't have bolts to mount gearbox.
Hopefully someone has their bolts out they haven't installed yet and could tell me. I know there are some Chevy gods on here with that knowledge in their head Getting ready to start tearing my daily driver apart and let's hope I can find bolts at Lowes/HD tomorrow. Bought every belt size I could look up at AZ, want to replace with GM when I know correct size. Hopefully I can use the Doorman rag joint until I can get OEM type...might also steal off my 70 camaro. Thanks in advance!
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) Last edited by 9teen69; 02-01-2014 at 10:35 PM. |
02-02-2014, 08:55 AM | #2 |
Re: Bolt length for P/S on 72
i would use the old bolts from the manual steering box, should be the same...you might have to get some a little longer
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
02-02-2014, 08:56 AM | #3 |
i would take the belts back and mount everything first , then go back to the store and get the one listed for a stock set up and go from there on your measurement, you might get lucky and get the right one first
02-02-2014, 09:01 AM | #4 |
I did same conversion a couple years ago. Used same bolts from manual gear box. A trick I learned on belt size is to take a sturdy wire or small diameter rope and after everything is mounted, run said rope/wire on same route as the belt will be on. Use that length for your belt size.
02-02-2014, 10:52 PM | #5 |
Thanks bigmac73 and gipper, the 3 manual gearbox bolts worked and I scrounged up an extra in the garage.
Forgot I needed a coupling to mount to gearbox side. Luckly my 70 Camaro coupling was the same size. Poor Camaro will never get pack together.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
