Patch panels line up
I bought floor patch panels from top banana for a 65 chevy pickup, the hole in the patch panel to bolt it to the frame does not line up. Is it because its a panel? Are the frames on the panel the same as a pick up?
Re: Patch panels line up
I had the same problem with floor patch panels from Top Banana for my 65 K-10. I cut, moved and re-welded them lining the hole up where it needed to be. I just blamed it on being an aftermarket panel and moved on.
http://www.67-72chevytrucks.com/vboa...=586095&page=2
Post #28. I had the same problem, that's how I solved it... |
I had the same issue. The patches I bought from top banana were very high quality, but the holes didnt line up. I considered this minor, as most people have to do significant modification to get patch panels to even form up correctly.
Thanks for the response, looks like ill do the same. Do any of you know if any make the reinforcement donuts for that bolt?
Had the same issue with mine: http://67-72chevytrucks.com/vboard/s...6&postcount=55
I don't know of a supplier. I just whipped one up out of sheetmetal and tacked it inside the cab support before installing the floor pan. |
Grandpa54, I misunderstood what you were talking about until your other post. I thought you meant to lower door pillar holes. Here is what I did. I replaced the sheet metal, separated the donut from the old rust metal, cleaned and painted the back. I used a bolt with a little paint to mark where the bolt came up from the bottom and hit the floor pan, that's where I drilled my hole and hollowed it out until the original donut fit, then I tacked it in place. Hope this helps.
![]() ![]() ![]() Good luck! Let us know how it goes. |
| Bookmarks |
