02-02-2014, 07:33 AM | #1 |
Want to Trade for I6 Iron Headers
Looks like I have an intake. Still hopein to locate Cast iron exhaust headers, I suspect the Langdons are the only ones out there in cast iron for the 194-250 engines. Let me know if you want to work a trade for cast iron headers.
Looking for a good stock Chevy 1 bbl Intake Manifold for 250 Chevy I6 and Cast Iron dual outlet headers/manifold I have the following parts to trade - 64, 65. (Will add to the list as I inventory.) Prefer trade, Would trade all for both manifolds. Heater box, engine bay side, no core but with lid and motor mount plate, motor works but bearing squeals Heater plenum, cab side, with 3 speed coil 2 new LMC Lower Ball Joints Good door glass - left and right Good back glass - Small I6 points dizzy + Coil and coil to motor bracket 64 C10 fender badge 2 hood hinges 3 speed shift rods (Column to trans) SM318 non granny three speed trans Brake pedal with cross shaft and plastic bushings 1 white painted (light rust) headlight square trim piece 1 T3 headlight (High/Low beam, 7" Diameter) All three of the 1964 chevy brass brake t-fittings, DS Front (1/4" lines in and out), PS Front (1/4 line in, 1/4 line out, 3/16 line out), DS Rear (brake hose in, 3/16 lines out) (Rear is 1964 specific, different fitting and mounting was used on the 1965 models - but the Fronts are the same both years.) PM Please. Last edited by Sharps40; 02-03-2014 at 09:09 PM. |
02-02-2014, 07:39 AM | #2 | |
Re: Want to Trade for I6 Intake Manifold
02-02-2014, 10:34 AM | #3 |
PM sent
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
02-02-2014, 04:29 PM | #4 |
PM sent
02-03-2014, 09:17 AM | #5 |
02-03-2014, 09:18 AM | #6 |
02-03-2014, 12:20 PM | #7 |
PM sent.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-03-2014, 12:27 PM | #8 |
Some pics of the one I have.....
02-03-2014, 08:24 PM | #9 |
