Old 02-02-2014, 04:12 PM   #1
Kennuck
Kennuck's Avatar
Western 2.5 drop spindle hitting upper A arm
Just about done my Western Chassis Drop spindle install and as I was torquing the ball joints noticed this. The spindle is hitting on the upper A arm where the ball joint attaches. Anybody have this problem? Does it just need a little trim. This is steering we are messing with want it done right.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 02-02-2014, 05:11 PM   #2
tony58
Re: Western 2.5 drop spindle hitting upper A arm
Do you have your suspension in the normal driving position? Just grind a little off the a arm edge
tony58 is offline   Reply With Quote
Old 02-02-2014, 05:19 PM   #3
pritch
pritch's Avatar
I had the exact same thing on my 2.5" drop, but mine is the McGonwhatever brand. Mine had a little bumps, kind of a raised up piece, that I ground off.
But I believed then and I believe still that once all the weight is back on, it would have cleared.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 02-02-2014, 05:40 PM   #4
rwhit57
rwhit57's Avatar
I think the others are right, with the weight back on it, it will be fine, but I would probably grind some off of the spindle if anything. There is plenty of meat there.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 02-02-2014, 06:08 PM   #5
Kennuck
Kennuck's Avatar
Yeah I didn't think about the suspension being at full droop. It clears when there is weight on it. Still it shouldn't hit at all, what happens when I do my Bo Duke impression and get some air, it's going to pull that ball joint apart.
I took my die grinder to the A arms its all good now.
Thanks for the help guys.
1970 Short Wide
Vintage Air
Old 02-02-2014, 06:22 PM   #6
Kennuck
Kennuck's Avatar
After getting by this minor problem I gotta say I'm pretty happy with Westerns spindles. Plenty of room for 8" Rallies even rusty ones haha.
1970 Short Wide
Vintage Air
Old 02-02-2014, 06:50 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Kennuck, I want to point out that your upper ball joints are bolted in wrong. Notice how Pritch has his where the bolt heads are underneath and the nuts on top. His is correct. The reason is, when installed like you have them, when you fully inflate the ball joint boot with grease, the exposed ends of the bolt can rub through the rubber boot during driving conditions.
Old 02-02-2014, 07:29 PM   #8
Kennuck
Kennuck's Avatar
Thanks Tx that makes sense. I just looked closer at the instructions and it shows them going as you describe. Luckily I haven't inflated them with grease yet so I will flip them around.
1970 Short Wide
Vintage Air
Old 02-02-2014, 07:34 PM   #9
Kennuck
Kennuck's Avatar
I cleaned painted and re assembled my entire front end this weekend. All new A arm bushings and ball joints and installed my drop spindles. It was a busy couple days working all by myself but other than this small mistake all is good. To be honest I was more worried about threading those bushings into the A arm and shaft at the same time but that went pretty smooth. Live and learn.
1970 Short Wide
Vintage Air
Old 02-02-2014, 11:53 PM   #10
pritch
pritch's Avatar
Man, I made that same mistake, too
Someone here pointed that out to me, too. Putting them in from the top just seems natural.
'68 Panel
'68 C-10
Ol' Green
Old 10-26-2014, 07:08 PM   #11
Doug19
Sorry to bring this back up but I'm having the same issue. Also my ball joints say to torque down the nuts to 40-55 ft. Lbs for the upper. If I do this the nut is way past the hole.for the cotter pin and the spindle rubs big time. Any idea what doing wrong?
Doug19 is offline   Reply With Quote
Old 10-26-2014, 07:17 PM   #12
Doug19
I'm going to have the same issue with the lower nut too. I can turn it by my fingers and it is almost past the hole. I have 3" drop springs if that matters.
Old 10-26-2014, 07:28 PM   #13
Kennuck
Kennuck's Avatar
What year is your truck? 71-72 ball joints have smaller taper than 69-70.
1970 Short Wide
Vintage Air
Old 10-26-2014, 07:43 PM   #14
Doug19
All parts are for a 72
Old 08-24-2015, 07:57 PM   #15
88Stanger
88Stanger's Avatar
Thanks for this, I am dealing with the same thing. Thanks again
88Stanger is offline   Reply With Quote
