Hose from windshield washer
Can someone tell me where it hooks up? I assume a pump that would spray it. Maybe Im missing something.
Is it under the hood or in the cowl?
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
Re: Hose from windshield washer
Under the dash
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4 |
Ok. So it does go through the firewall. Found it dragging under my truck. LOL
Yep 1 in 2 out I believe
The Older Generation
Outlets are on the windshield wiper motor. LockDoc
Thank you guys.
![]() Join Date: Jan 2001
BUT...
If you want a great and easy upgrade, a washer bottle with integrated pump from an S-10 does a lot better job than the factory unit and it's easy to wire to the existing switch. |
![]() Join Date: Mar 2012
any thread or link available to cover that ?
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Try this one...
http://67-72chevytrucks.com/vboard/s...d.php?t=555852 It also shows how to wire it to your wiper switch. LockDoc
