Old 02-03-2014, 12:14 PM   #1
hartbraker
2000 Chevy Seats in my 86 Silverado
I've got a set of seats out of a 2000 Chevy, the ones with the seat belts in the shoulder of the seat, and a center console out of a 2013 Chevy (which is the same width as the center console from the 2000 Chevy).
I can post pics tomorrow, but I have a couple questions.
My thoughts are that I will be able to use my factory bench seat mount and attach both seats and the center console with some sort of mounting tabs to the original brackets. However, I have never done the seat swap before and was hoping someone who had would be able to chime in.
Either way, I'm positive I'll be able to figure something out... just hoping to have a little inside knowledge to avoid possible hiccups.
Anyways, here is a picture of the truck in question... since I know how much everyone loves pics here!
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
Old 02-03-2014, 12:23 PM   #2
hartbraker
Re: 2000 Chevy Seats in my 86 Silverado
Ok, so I was able to find the pictures today. So, here are the seats and center console in question. BTW, I LOVE the lockable storage under the seat in the newer center console and the fact that the cup holders are in the center console and not in the way of the transfer case shifter. Hope you enjoy!
Old 02-03-2014, 02:26 PM   #3
nekkidhillbilly
yes you just use a your old seat brackets. be aware your seats arent as wide as the old one and still set up higher.
nekkidhillbilly is offline   Reply With Quote
Old 02-03-2014, 02:41 PM   #4
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
You cant just use your old brackets. Those seats have integrated slides/bracketry that ties into the structure of the seats.
Your looking at fabbing the seats to fit the truck, or the truck to fit the seats.
bowtieguy79 is offline   Reply With Quote
Old 02-03-2014, 02:48 PM   #5
nekkidhillbilly
you can cut the brackets off and drill holes to bolt it onto old sliders. still not the best setup. ford seats are better in these trucks due to its raised floors.
Old 02-03-2014, 02:57 PM   #6
bowtieguy79
Ephesians 2:8
This doesn't look to be overly sturdy, but they are in there, and look nice!
http://67-72chevytrucks.com/vboard/s...ght=99-06+seat
couple other options
Old 02-03-2014, 03:06 PM   #7
nekkidhillbilly
those newer ford seats for example is what im talking about in your second post they look perfect
Old 02-03-2014, 03:17 PM   #8
hartbraker
Ya, there's no way I'm drilling new holes in the floor. The original brackets will have to do depending on how much higher the seats sit. Ill remove the new seats from their bracketry and make some mounting tabs that will allow me to bolt them down to the orginal brakets.
I suppose Ill be able to figure it out when I get home, but you wouldn't happen to know how much narrower the new seats are by chance? Hopefully not by much and I could just space out the seats slightly to split the difference....? Thoughts?
Old 02-03-2014, 03:28 PM   #9
nekkidhillbilly
its about 3.5 i think
Old 02-03-2014, 03:38 PM   #10
hartbraker
Oh, that's not too bad. I can live with that.
At any rate, you guys can tell I have charcoal seats and a tan console on the way. Any chance you guys have a line on a set of oem seat covers for the 01 chevy to make them match the console?
Old 02-03-2014, 03:45 PM   #11
bowtieguy79
Ephesians 2:8
http://www.katzkin.com/
We put a set of these in my brother's 04 GMC. Nice stuff. You'll be hard pressed to find OE that isn't beat up.
Old 02-03-2014, 04:07 PM   #12
nekkidhillbilly
could dye the the console
Old 02-03-2014, 04:12 PM   #13
hartbraker
Well, I could dye the console... but I'd prefer for the interior to be the color of the console. My door panels, dash, and trim pieces are already tan.... So it will be much more cost effective to find an appropriate / good fitting cover as opposed to changing to a different interior color.
Plus, I want it to be tan.
Old 02-03-2014, 04:16 PM   #14
nekkidhillbilly
dye the seats tans
Old 02-03-2014, 04:26 PM   #15
hartbraker
I guess I'm not very familiar with the process of dying... I didn't think it was an option to dye cloth... but that very well could be the route I take. Thanks a lot for the input guys. I appreciate it.
Old 02-03-2014, 05:03 PM   #16
nekkidhillbilly
yeah you can dye cloth with sem dyes pretty well. prob take a few coats due to going from dark to light. ive seen black to white in leather even.
Old 02-05-2014, 01:21 AM   #17
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I've got the exact same setup in my 87.. The nicer seats found in 99 newer v8's and the console out of a 2008 or 09 as pictured. Fits nice but custom brackets. In a nut shell uses the 87 slider, square tubing ontop welded to it or bolted forgot.. The. The bucket bottom bolted to the square tubing. Then cut the seat back tabs off and welded them to the square tubing.. I don't have recline feature.. I would have had to notch the floor and not something I wanted to do since the gas tank is right under the area I needed to notch.. Measuring the factory 2000 style seat spacing is what was key in fitting well.
I'm using the 87 seatbelts
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-05-2014, 09:08 AM   #18
hartbraker
Clint
Nice to hear someone shares the same taste. Anyway, any particular reason you decided to stay with the factory seat belts? Seems so simple to just use the shoulder belt built into the seat... just curious
Old 02-05-2014, 07:08 PM   #19
nekkidhillbilly
i like the looks for used seats though the fords have a better set up.
Old 02-05-2014, 10:15 PM   #20
87chevy.com
mostly since i didnt use the factory 2000 style seat frame and its facotry style bolt to the chassis. the factory rail it sat on makes it really high and im 6'6" and would not have been comfortable in my own truck. the way i did it is great, head room and everything. plus the truck seat belts were designed that way and didnt want to mess up the only saftey system in my truck...
clint
