I am wanting to get some primer for some parts, And I hear the words 2 part epoxy primer. I know about the epoxy primer, but don't understand the 2 part, Does 2 part mean mix with reducer and primer, and spray only one time, Can someone help???? Thanks!
------------------ 72 CHEVY FLEETSIDE 4X4 SHORTBED,8" SUSP. LIFT, w/ soon to be 38" Swampers (IN RESTORATION) 1967 CAMARO (283 CU.) Dillsboro, Indiana.. AOL IM: HIGH724X4 I am NOT Addicted to the Board (PLEASE HELP!!!)
72 CHEVY FLEETSIDE 4X4 K10 (SOLD TO JAMIE72, BUT BLAZER GAL PULLED AWAY WITH IT LOL!!!) Will Own one Again!!! 1967 CAMARO (PRO-TOURING PROJECT) Lawrenceburg, Indiana.. AOL IM: kbillcad |
![]() Join Date: Jan 2001
It means that you mix the paint with a hardener and then spray the mixture. With the DuPont product it has to stand for a hour or so after mixing and before spraying.
Bernie |
![]() Join Date: Apr 2001
It also means you need to wear special respirator! Stuff can kill you if you don't know what your doing and have the right equipment and ventilation. Check with a pro on this one!
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps |
Yes, that is one downside of 2 part, it is VERY bad to breath. I used a fresh air resp. when I sprayed it. (line going outside for fresh air). Learned the hard way though. Sprayed a sandrail chassis with it once, no resp. coughed for days. Probably didn't help the body any either.
You can buy a fresh air for about $200 I believe, or rent them also. ------------------ Jeff Scott '70 GMC Stepside, Short box '67 Camaro '63 Nova '92 GMC typhoon
Jeff Scott '70 GMC Stepside, Short box '63 Nova '92 GMC typhoon '95 Tahoe |
two part you mex only what you are going to need. The unused stuff will last a lot longer than a one part and it is a better quality. DUPONT you don't hace to let it sit for an hour before spraying I use the stuff every day it is PPG that you have to let sit for one hour before spraying.
68 gmc 70 chev |
| Bookmarks |
