Old 02-03-2014, 05:34 PM   #1
Moreyel
Moreyel's Avatar
Fuel gauge readings 72 Blazer 4WD
I've gone through many threads & discussion on solving inaccurate gauge readings. I followed the instructions I found and here are results: I disconnected the tan wire from the fuse box and the gauge goes to 1:00, just past full but not to 3:00 like they said it should. Grounding the gauge wire term on fuse box takes it to MT, which from what I read is normal. So with key on and float in lowest position, it reads MT. With it in the up (full) position the gauge goes to 1/4 and stays there.
Any ideas?
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2020 Ram 2500, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more.
Wife: 06 GMC Duramax 3500 4WD Single Wheel
Next: Rust removal on my Blazer.
Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup.
Members Met: Aldtime, DeadheadNM
Moreyel is offline   Reply With Quote
blazer fuel gauge, fuel gauge test, sending unit test
