mmmm....Rye and Coke
Tilt Steering
Is it as simple as removing and replacing the steering columns, there is nothing else to it is there?
It followed me home?
right, very simple
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Cool, thanks, that's what I thought
One thing I found is that I had to use the lower steering shaft from the same truck as I got the steering unit from. As my Bonanza tilt wheel steering shaft was splined with a clamp, the one from the Silverado had a flat ground and a through bolt.
BAD BOW-Silverado XST
Use an 84 and up for your truck. The older models don't have the wiper option on the column.
