Old 07-21-2003, 10:29 AM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Wheel size and back spacing
My blazer is 4wd. From what I have learned the wheel size on my truck is 6-139.7 or 6-5.5 pattern. What I am confused about is the numerous wheels that are advertized with these dimisions. How do I make sure that it will fit over my hub lockout? And what back spacing do I need. I really not looking at anything really hard I just would like to know incase a good deal comes my way.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 07-21-2003, 10:54 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
For the most part if the wheel is advertised as a truck wheel it should fit. I had 15x10 w/ 4" backspacing white wagon wheels on an 85 K5. Fit no problem.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-24-2003, 01:16 PM   #3
JayDubBlazer
go cyclones
I was wondering if these wheels would fit? If so how much back spacing? The specs are-
WHEEL MATERIAL: Alloy Aluminum
MODEL: Series 301
WHEEL SIZE: 20 x 8.5
FINISH: Super Finish (Polished Machined)
BOLT PATTERN: 6 on 5-1/2"
OFFSET: +14mm
BACKSPACE MEASURMENT: 5-1/4"
HUB HOLE DIAMETER: 108.20mm / 4.26"
They are on ebay at
http://cgi.ebay.com/ebaymotors/ws/e...item=2424791811
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 07-25-2003, 05:02 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
That's a lot of back spacing.
Old 07-25-2003, 01:50 PM   #5
GreenMystChevy
That does sound like a lot of backspace but then again, I am curious as to how much we can get on the 4x4's. I know at least 4" so I was thinking I'd try to go 4 1/2" unless someone tells me otherwise.
BTW: do you happen to know what the bolt patter for the '72 8 lug 3/4 ton axle is?
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 07-26-2003, 10:20 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
8 on 6.5"
Old 07-28-2003, 12:49 PM   #7
GreenMystChevy
thanks
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Old 07-31-2003, 04:00 AM   #8
JayDubBlazer
go cyclones
Wheel adapters
Has anyone used these? Are they a good way to adjust for back spacing. They offer sizes from 1" to 4"
http://www.truckaddons.com/Catalog/s...ls_adaptit.htm
thanks
Wes
PROJECT OLE GREEN
2017 Silverado LT
