BMW & ASE Master Certified
Stupid question, but since your hear, I'll give share a neat trick I found out not to long ago. I actually just broke 2 tabs off of the little a/c vent on the driver side when removing the interior harness... I super glued the pieces back on, and thats not the neat trick... the neat trick is adding super glue to the back side where the crack was and lay on some baking soda.. in my case it was right where the tab starts (it makes a 90 degree bend)..
so for the skinny: I laid out some wax paper, made a small pile of baking soda and got my exacto knife out. Squeezed some super glue in the corner and sprinkled some baking soda on the super glue and tapped the part so the baking soda got all into the super glue. It instantly hardens! I did this process only 2 times on each broken tab and rock solid. for kicks and giggles a I had a tootpick and coated it in super glue and rolled it in the left over baking soda and repeated once more.. that sucker was difficult to break in half! Anyway, Im sure someones like psst, you didnt know that?? but somone will be like, damn.... and use it next time a plastic tab or something breaks.. Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Re: Anyone ever broken a plastic tab off anything before?
![]() -repaired
Awesome! Fixing my cluster tabs tomorrow!!
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
Excuse me, your genius is showing.
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
Neat trick!!
Another trick, acetone can be used to repair ABS plastic. Just put it on like glue and stick the pieces back together. The acetone melts the abs and evaporates quickly leaving the pieces welded together and as strong as new. I know at least some of the grills are ABS, dunno what else is...
I got it from youtube... was browsing for something... and like all things on youtube, one thing lead to another and this is similar to a product napa or advance sells.. also used this to repair my moms china made china cabinet.. the leg riped off during a move and unable to glue it on since there was a big chunk missing from the bottom... put tape on the finished side and started layering the super glue, baking soda in little stages till it was filled in. Drilled the hole, counter sunk the hole and repaired... that was the first time I used it and I was like damn.. needless to say next time I go grocery shoping Im going to pick up an extra box and bring it to work and put it in my tool box... damn BMW's are built with so many plastic panels and parts
![]() clint
So...where's the science? (lol)
What's the baking soda do? Are you suggesting it becomes a "filler" (to aid in building up material) or are you saying the baking soda makes the super glue "harder" in some way? How would this be different then adding plain super glue to the back of the break? I seek to understand... K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Excellant !!!!!!
2004 Silverado Crewcab (Dark Spiral Gray) |
Keith: Your "science"
![]() From the site: Accelerators Besides water, cyanoacrylate polymerises also in presence of alcohol and basic compounds (including weak amines). The latter can be used to produce a superglue “kicker” – a compound which triggers quick polymerisation of the glue. Baking soda is one well-known substance with this effect. If you apply a layer of superglue to a seam and gently pour baking soda over it, the glue will cure very quickly. It makes for most effective filler for smaller jobs, and the baking soda results in a slightly rough surface which is good for sanding. "
1980 Chevy K10 Silverado --> Build Page My wife told me I spent too much time on Facebook. So I bought an old truck. Now she wishes I was on Facebook, it was cheaper. ![]() |
Never heard of this little trick before, Thanks for sharing
#12 | |
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
#13 | |
Thanks!
#14 |
Thanks for the info,now i know how to fix the china plastic on the wifes car.lol
#15 |
Thanks, broke a tab on the instrument cluster last week so this is good.
The other neat thing was that you can color match it by using food coloring to tint the baking soda; let the baking soda dry and crumble up it up again and the repair will be that color.
1980 C10 Custom Deluxe, 250 L6, 3 in the tree. |
#16 |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
Awesome tip! You should add it to this "Cheap Tricks" thread!
http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#17 |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Nice info. Now I have to look for something to fix.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
#18 |
78K & 79C Jimmys
neat fix
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#20 |
I need to remember this trick. Thanks!
Alex. |
#21 |
Great info, fiberglass with epoxy works well on larger parts as well, but its only as strong as the glue bond.. don't forget to scuff and clean your parts, soda works on guitar nuts too
1987 GMC Wrangler 350/700r |
#22 |
Was browsing here to see what I could find on fixing broken tabs on the instrument cluster and came across this thread. Gave the super glue/baking soda procedure a try and by golly it worked pretty good. Fixed 2 tabs and they seem to be really solid. One thing thats nice about it is its almost instant and you are done.
http://67-72chevytrucks.com/vboard/s...d.php?t=588707 |
#23 |
This looks like a good idea http://www.eastwood.com/ew-hot-stapl...ir-system.html
#24 |
I bought this stuff at a rod run a guy was pushing that bonds any molecule. I asked if it would bond anything besides molecules? He smiled and said "no". But that's what I use. He cut a piece of rubber, then put the stuff on, wait maybe 30 seconds, then had me pull one end while he held the other. It just stretched and stretched. Then he cut the bonded section out and cut it in two length ways and you couldn't tell it had been cut, no seem, no residue, looked untouched. It's called Tech-Bond. He says Super Glue is old technology. So far it hasn't let me down
www.tech-bond.net
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-27-2016 at 10:09 PM. |
#25 |
The Older Generation
Good tip Clint.... I need to try that.
I bought a glue called "Fusion" at the state fair last fall. I needed to make an "O" ring type belt for my table top band saw so I went out to the shop and got a piece of 1/4" OD vacuum hose, cut it to the right length and used the "Fusion" adhesive to glue it together. Worked like a champ.... LockDoc
Tags |
plastic repair, super glue mod |
