Old 02-03-2014, 10:20 PM   #1
9teen69
9teen69's Avatar
What pulley am I missing for PS setup
Trying to finish up my power steering conversion. Need to drive it to work in the morning.
Looks like I need a spacer or different pulley.s
Here's the numbers on the pulleys I have
Drive: 3751232BB - single and 3744043BA - double
WP: 3995646AH
PS: 3925537DC
So close!?@#...
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 02-03-2014, 11:32 PM   #2
BigRed76
BigRed76's Avatar
Re: What pulley am I missing for PS setup
Looks like you either have the wrong PS pump or it somehow got mounted too far forward. The PS pulley should line up with the front groove on the crank pulley.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-03-2014, 11:52 PM   #3
9teen69
9teen69's Avatar
Sorry I can't get the photos turned. I'd take more but I've already taken it apart...again.
I can't seem to find any photos of the PS pump going to the first groove.
Old 02-04-2014, 12:07 AM   #4
9teen69
9teen69's Avatar
Found these photos, looks like the cast one is what I need. Anyone know where I could get one?
Old 02-04-2014, 02:03 AM   #5
kevmac
kevmac's Avatar
Can the p/s only work on a 3 groove crank pulley? not 2?
kevmac is offline   Reply With Quote
Old 02-04-2014, 04:10 AM   #6
FirstOwner69
FirstOwner69's Avatar
Were the parts you used for the P.S. conversion a matched set from the same vehicle?
I have seen 2, possibly 3, different types of P.S. pump pulleys on these trucks. Some have the belt groove closer to the radiator than the more common pulleys I've seen which place the groove closer to the pump. My 69 with A/C and the early style A/C brackets had the pulley with the groove close to the radiator and used the crank pulleys you show in the picture in post #4 along with a 3 groove water pump pulley. From your pictures in your first post it appears you have this type of "flat" pulley. Here is a link to an eBay listing for a pulley similar to (same as???) those which position the groove closer to the pump. This might solve your problem. You'd have to confirm diameter and shaft size before ordering.
http://www.ebay.com/itm/261360229613...84.m1423.l2649
And, this one looks more like the one in your picture and the one in my truck.
http://www.ebay.com/itm/261388413936...84.m1423.l2649
This is the cast one you show in post #4 which was used in tandem with the other in post 4 for my A/C truck.
http://www.ebay.com/itm/201028097705...84.m1423.l2649
This could turn into a trial and error proposition for you.
FirstOwner69 is offline   Reply With Quote
Old 02-04-2014, 08:21 AM   #7
bigmac73
bigmac73's Avatar
i would call a tech at summit and tell them what you have and what you are trying to do, they might be able to point you in the right direction
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-04-2014, 09:14 AM   #8
jjzepplin
jjzepplin's Avatar
Mine was on the last groove of a triple groove aluminum crank pulley. Short water pump type system.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-04-2014, 10:14 AM   #9
68shortfleet
Your system looks identical to mine except for the PS pulley. My pulley is offset deeper towards the pump.
I have a spare cast crank pulley that I would be happy to sell, BUT I don't think it will fix anything for you. OR, I could get you a part number off my PS pulley that I think would fix your problem.
Any possibility of a picture of the PS pump brackets?
68shortfleet is offline   Reply With Quote
Old 02-04-2014, 10:15 AM   #10
68shortfleet
Double post
Old 02-04-2014, 10:43 AM   #11
9teen69
9teen69's Avatar
Thanks for all the input and help. firstowner69 nice research man...predicate it!
68shortfleet - Yes, I think I just need the recessed PS pulley like yours. Part #? Your PS bracket is the same as mine.
or I can go the cast offset pulley route. Either route I need to order today for next day shipping.
Old 02-04-2014, 10:49 AM   #12
msgdsrf
Offset pulley, should line up with third groove on crank.
http://www.alangrovecomponents.com/Pulleys_2011.htm
Lots of info here on dimensions
msgdsrf is offline   Reply With Quote
Old 02-04-2014, 11:11 AM   #13
9teen69
9teen69's Avatar
Nice link. Part # 507 right?
Old 02-04-2014, 11:27 AM   #14
68shortfleet
The part number on my PS pulley is 3770509CE.
I am nearly positive that the cast crank pulley will not take car of this issue for you. But, I have one if you want to try it...
Old 02-04-2014, 11:42 AM   #15
msgdsrf
If your bracket is the same as you mentioned earlier (basicaly OEM style), Yes. #507 is pretty much the standard to align with third groove crank pulley, standard on these years..
Old 02-04-2014, 11:45 AM   #16
msgdsrf
Looking at your water pump pulley, looks like your're going to have AC as well? That looks like it lines up good. You can sometimes need shims in either the water pump pulley or crank pulley to get it all perfect, just an FYI and not completely necessary.
Old 02-04-2014, 11:47 AM   #17
9teen69
9teen69's Avatar
Thanks everyone for the help, going to order #507 from that site.
