02-04-2014, 12:13 PM | #1 |
Got the call dad my brakes went out.
The boy was driving to work last night. Then I got that call DAD my brakes went out, He is okay as well as the truck he got it stopped on the side of the road using his parking brake.. When I got there I drove it and they seemed okay. Not sure if they where just froze up or what, it has been very cold the last few weeks . So we got it home and know we are thinking we should replace the brake master thinking it isn't working right. He is wanting to upgrade to power so know the search goes on to find the set up for that.
http://67-72chevytrucks.com/vboard/s...0&referrerid=0 |
02-04-2014, 12:41 PM | #2 |
Junior Member
Re: Got the call dad my brakes went out.
I would definitely get the master replaced. I had the same thing happen to me a couple of years back. Going down a hill the pedal went to the floor. After pumping it a few times I got a little pressure (enough to stop). Same thing happened all the way back home. Replaced the master and all was good.
02-04-2014, 01:35 PM | #3 |
Glad he knew how to get it stopped safely. I had that issue a few times with old VWs, part of the allure of four wheel drum brakes.
I agree, this may be a good time to upgrade to a newer master, and a booster. My issues stemmed from old hoses, and worn wheel cylinders. What kind of shape are yours in?
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 |
02-05-2014, 01:22 AM | #4 | |
02-04-2014, 02:32 PM | #5 |
20' Daredevil (Ret)
In the meantime, teach him how pump the brakes. Not a fix, but it usually works well enough to slow you down in an emergency. Everyone who drives should be ready & able to pump the brakes if needed.
02-05-2014, 01:25 AM | #6 |
Yes he got a free lesson on pumping those bad boys. That's what he did all the way home. He is parking it tell he gets paid next Tuesday as he can get a new master then. plus its snowing so its sitting for a few days.
02-04-2014, 03:21 PM | #7 |
Agreed! You don't really learn how to drive until you've stopped sans brakes a couple times! E-brake, downshift like a mo-fo, dodge approaching objects, hit the horn, crap yourself... If you accomplish all that without death or dismemberment, you are then a MAN!
02-05-2014, 01:29 AM | #8 | |
02-04-2014, 03:29 PM | #9 |
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
02-05-2014, 01:34 AM | #10 | |
02-05-2014, 03:01 AM | #11 |
Fyi 40+ yo brake boosters are kind of a crap shoot as far as whether theyll work or not. I went through three second hand ones before i used the last one as a core for a rebuilt one. Granted all of the brackets were useable, but with all of the time i wasted, i probably would have been better off going with the summit setup, or one from CPP. Maybe dad could spot him a few bucks (?)
02-05-2014, 01:40 PM | #12 | |
02-05-2014, 04:55 AM | #13 |
Had that happen once. Changing the engine in my 66 Chevelle I had pinched (or PO ) the brake line running under the front engine cradle. Hard braking it would just barely seep a bit til finally I was out of fluid. Real hard to find as it just looked like a small oil leak. Four speed Muncie so down shifting was not a problem. Cleaning my pants after the intersection near miss was an issue.
Go through the whole system as the truck is replaceable. Your son is not.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-05-2014, 01:48 PM | #14 | |
02-14-2014, 11:00 PM | #15 |
Okay today after school he wanted to put his new master cylinder on, it was about 25degress out and snowing. (just a dusting) We are going to bleed the whole system out maybe tomorrow depending on the weather. I had it bench bleed for him before he came home so he just had to undo the old and install the new one. After we called it quiets for the night, we were freezing. we noticed that his water pump was leaking... Damn it. So he was going to get a new one tonight on his way to work, guess we are doing that also this weekend....... Fun fun.
02-15-2014, 02:58 AM | #16 |
I had to run a red light once (I looked both ways) when my '75 Pontiac lost her brakes.
I learned to pump brakes real fast too! |
02-17-2014, 02:07 AM | #17 |
Wow, Had this happen to my 70 nova when we still lived in Vegas.
02-17-2014, 02:12 AM | #18 |
We got it all done and he drove it to work today. No problems with the brakes or the cooling system. But it did burn out a headlight.
03-03-2014, 03:02 AM | #19 |
We did have to change out the new master, It was leaking from the lid they gave us a new one and it still leaked so they gave us a new one not a remanufactured one so now its all better. We put it to the test and loaded it up with some stuff from our storage unit. worked just as we wanted it to.
