02-04-2014, 12:46 PM | #1 |
if you have swapped for a 73-86 frame, can you post pics pls?
Hey guys,
I have a 59 that I got a great deal on, and also a free 85 heavy half for a donor. I am looking to do the frame swap but I am getting conflicting reports as to wheel fitment up front, if you have done this swap, could you post a pic in this thread with what wheel/tire combo you are using and any mods you had to make to the front to tuck tires. I would like to have a look and see what my options are. Thanks, Mike |
02-05-2014, 12:41 AM | #2 |
Re: if you have swapped for a 73-86 frame, can you post pics pls?
78 1/2 ton with 35s. The rear leaf springs mounts were moved 4" forward. I mounted the core support with 2 6" vertical mounts straight off the frame. The front cab mount is about 7" and the rear cab mount is on 1/2 bushings. Still working on the bed mounts but is is not that complicated. I could not find much out their so I just went for it. So far so good. Just take a lot of measurement and do what looks good to you.
02-05-2014, 01:37 AM | #3 |
02-05-2014, 09:26 AM | #4 |
http://www.e-zchassisswaps.com/about.php check this guy out
02-11-2014, 12:32 PM | #5 | |
02-11-2014, 12:34 PM | #6 |
02-12-2014, 01:11 AM | #7 |
Tires are too big. 255/50r20.(bought them for rollers) They would probably hit the wheel well. Planning on a 235 profile tire. Wheels are MB "old school" 20x8. The narrower tires will allow it to tuck over bumps. If not I would just have to roll the inner fender lip.
02-23-2014, 01:54 AM | #8 |
'58 Series 40 Viking
'82 Crew cab donor
ColoradoMelons.com |
02-23-2014, 03:06 PM | #9 |
I keep looking at the 1-1/2 ton 51 I have out in the back yard and thinking about doing what Jackdaddy did with his truck. That would make a hauler that I could jump in and drive anywhere for a reasonable cost.
02-23-2014, 11:43 PM | #10 |
The "Big Bolt" ton-and-a-half front end eliminated all the "wheels sticking out of the fenders" I've heard about from the 1/2 ton-ers. Cabs are exactly the same regardless.
Marc's 55 looks good in 4x4 trim however.
