Old 02-04-2014, 01:27 PM   #1
70inbville
engine position question.
Hello all,
I want to hide my coil packs between the heads and the firewall, I have been searching and can't find a good answer of what mounts to use to get enough room. all help is appreciated.
Thanks Chip
70inbville is offline   Reply With Quote
Old 02-04-2014, 02:18 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: engine position question.
You can use slider mounts to put it forward, or you can just use the regular swap adapters and move the position of the perches.
You can move the perches to the front frame holes for about 1" extra clearance. You can go fartehr forward as well, by using the front bolt as the rear, and making a new front mount (as long as the perch still fits to the crossmember properly)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-04-2014, 03:43 PM   #3
70inbville
thanks for the info!
