02-04-2014, 03:06 PM | #1 |
The mean lean
I kinda always knew my truck was leaning to the passenger side thought is was the cab mounts but it's the bed as well as the cab leaning toward the pass Side so now I'm assuming its a suspension thing not the cab mounts because the mounts wouldn't make the whole truck lean just the cab.. Am I right??!
02-04-2014, 03:12 PM | #2 |
Re: The mean lean
yep good ol square body lean
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
02-04-2014, 03:28 PM | #3 |
Re: The mean lean
So definitely a suspension thing
02-04-2014, 04:21 PM | #4 |
Re: The mean lean
Part of the problem is that a pickup cab and box are separate units, so you don't get the benefit of additional structure from the body like you do with a Suburban (or a passenger car) - which allows the frame to twist.
If that's the case the Cab might appear straight but the tailgate/box looks like it's leaning. I know I have a 1/2" spacer between the leaf spring and axle pad on my truck in order to square everything up. These things had "lean" when new, so I didn't spend a lot of time trying to root cause the problem. Just threw the spacer in there and haven't looked back. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-04-2014, 04:36 PM | #5 |
Re: The mean lean
The classic chevy lean. You can try and swap the leafs side to side and see if it evens up some.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
02-04-2014, 07:13 PM | #6 |
BAD BOW-Silverado XST
Re: The mean lean
I call it the torque lean!!
02-04-2014, 07:34 PM | #7 |
Re: The mean lean
hahaha! i will steal you this expression, torque lean
02-04-2014, 07:49 PM | #8 |
Re: The mean lean
My 85 short bed leans a lil on the driver side. I noticed a previous owner put some of those screw in spacers in the driver side coil spring.
02-04-2014, 08:31 PM | #9 |
Another Day, Another Dollar
Re: The mean lean
They all do it, don't bother trying to fix it. Your efforts will be futile.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
02-04-2014, 10:14 PM | #10 |
Re: The mean lean
This is lean I'm talking about it looks crazy
02-04-2014, 11:32 PM | #11 |
Re: The mean lean
Why do these trucks always lean on the drivers side?
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
02-04-2014, 11:45 PM | #12 |
Re: The mean lean
Idk.... But mine is leaning on the pass side as you can tell in the pic
02-05-2014, 09:15 AM | #13 |
Re: The mean lean
They don't. They lean every which way.
Mine was straight in the front but twisted, so that the left rear corner of the box was low. K
02-05-2014, 09:16 AM | #14 | |
Re: The mean lean
I'd start by getting the bumper to match the front of the truck and then go from there. K
02-05-2014, 12:00 PM | #15 |
Re: The mean lean
Mine has a 1" torque lean. The right bed side is 1" above the wheel than the left side. Drives me nuts. I hope lowered leafs will reduce some of the lean.
02-05-2014, 12:28 PM | #16 |
Re: The mean lean
Yea it's driving me nuts... The cab and the bed on pass side are 1 3/4 lower freakin weird.. I'm also hoping when I replace the leafs and coils and drop kit it helps if not then I guess it's spacer time lol....
02-05-2014, 12:54 PM | #17 |
Re: The mean lean
Unfortunately if you have the lean now, lowering it makes it look worse..I found that one of my leafs was broken so it did help to get new ones. Between shimming the bed-cab mounts to make it look straight at the bumpers, and then shimming the suspension like Keith said you can make it look pretty good.
02-05-2014, 05:13 PM | #18 |
Re: The mean lean
I thought the bumper was crooked because of the lagging suspension....
02-05-2014, 05:47 PM | #19 | |
Re: The mean lean
K
02-05-2014, 06:17 PM | #20 |
Re: The mean lean
Your right... So now I think we know it's a body mount issue
02-06-2014, 01:28 AM | #21 |
Re: The mean lean
I'm leaning toward cutting the front spring on non-lean side slightly - good idea or not?
02-06-2014, 04:07 AM | #22 | |
Re: The mean lean
My truck sat for years and years in the 90s on uneven ground. Made it all weird when sitting level. When I rebuilt the susp I got new front springs and took apart the rear leafs and swapped springs side to side till both leaf packs were the same.
02-06-2014, 06:09 AM | #23 |
Re: The mean lean
well since your truck leans to the passenger you could try to drink a 6 pack a night for the next 6 months and eat a double bacon cheeseburger at every meal to weigh down the driver side. haha just kidding. well maybe. my truck does the same thing. almost seems like a flat tire... but when looking at my truck the bed tilts down towards the passenger side but when driving it feels like its tilting towards the drivers side... still drives a straight line with no hands and brakes straight.
79' c20 std cab 292 3speed granny - daily driver. 77' c30 std cab 454 th400 4.10 - fathers truck then mine. 95' ford bronco 302 4speed overdrive. 2002 mustang auto v6 - girlfriends daily driver. Debt just means that you had more fun than you're suppose to have |
02-06-2014, 02:59 PM | #24 |
Re: The mean lean
Well I just measured the both front and rear bumpers on level surface and they both are level with the ground.. So sagging suspension is out now the only thing is could be is cab bushings and bed mounts am I right??? |
02-06-2014, 03:11 PM | #25 |
Re: The mean lean
That would be my guess..
